Question about Dishwashers
Frigidaire Dishwasher FBD1050REC4 dishes don't get wet & extra long cycle
Typically when a dishwasher is running and you open it water is dripping, things are wet. This dishwasher doesn't do that. The arm seemingly doesn't spin, dishes remain dry and a bit of water DOES fill up in the bottom of the dishwasher but neither the top nor bottom dishes are wet. The cycle seems to run exceptionally long as well. Thanks!
  • 2 more comments
  • Adam Tuliper
    Adam Tuliper Feb 11, 2014
    PS, arms spin freely by hand, they don't seem clogged as they have pretty big openings for water in them
  • Adam Tuliper
    PSPS when the dishwasher starts, I hear water coming in from the side hole, but never seems to hit the racks, assuming the pump under the filter tray is bad? how do I test it?
  • Adam Tuliper
    PSPSPS - after say, five-10 minutes it drains into the sink successfully. The pump never runs though to send it to the arms it seems.
  • Adam Tuliper
    circulation pump?
5 Suggested Answers
  • 42 Answers
SOURCE: dishwasher
I have seen this problem before on a couple of dishwashers.
How are the dishes doing? Are they coming out clean, or do some of them "fail".
If you rinse the dishes before putting them in the dishwasher, it may be hard to detect "failure" to clean. Try not rinsing the dishes once and run them through a cycle. My guess is that the "failure" rate will be high.
The problem I have seen is that the dishwasher water input filter is either clogged or the water-full sensor is "telling" the unit that there is enough water in before it actually fills properly.
So, some water can get in, but not enough to properly wash the dishes and dissolve the soap.
On the appliance repair sites they have parts breakdown details and what you are looking for is an input valve assembly -- the point just after the water line connects to the dishwasher.
Now the valve may be OK, but the feedback system could be bad.
(On a Bosch dishwasher the valve IS the feedback system and the filter.)
Any filtering or "water full" signal will feed back to that valve.
If you get inside that front lower panel, be sure to turn the electricity off first 'cause if you get crosswise in that area you could end up with a 'shocking' experience!
good luck
Posted on May 09, 2009
SOURCE: Hi, my Frigidaire dishwasher doesn't seem to clean
Factory Defect, where I was given full refund plus re-installation costs from Lowes...
Posted on Oct 17, 2009
  • 500 Answers
SOURCE: Dishwasher fills and drains, but water is not
Hi jpcoop,
Please look at my Tip I wrote about how to ensure your dishwasher is washing correctly, I believe your dishwasher should be cleaned in this manner at least once a month:
CLICK HERE - > DISHWASHER NOT CLEANING WELL...
Hope it helps
Regards
JEDEMEYER
* If this solution was helpful, please rate it
Posted on Jul 10, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: ffbd2407lm frigidaire dishwasher stops washing cycle?
    Sounds like you need a professional to diagnose the unit for repairs. You are either having a timer issue or a control board communication error.
    Posted on Aug 27, 2012
    Dishes not coming out clean
    Hello
    There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
    Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
    Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
    Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
    Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
    Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
    Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
    Sep 13, 2011 | Maytag Dishwashers
    Water not heating up and not drying
    Hello
    If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
    Incoming Water
    Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
    Thermostat
    The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
    Heating Element/Drying Fan
    The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
    Additional Concerns
    If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
    Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
    Frigidaire dishwasher won't end cycle - will run on and on for hours. Sometimes it cycles through, usually it just endlessly washes and rinses. I have to CANCEL the cycle, which causes the dishwasher to...
    I would say the resettable thermostat has failed. There is a thermostat which senses the water temperature, and when it fails, it causes the dishwasher to run constant. Replace the thermostat underneath the dishwasher and that should cure problem. Part number is 154290204 (I know the number off by heart, that's how often it happens!)
    Apr 07, 2010 | Frigidaire 24 in. FDBB540 Built-in...
    Dish feels hot but not drying
    sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
    Dec 15, 2009 | Kenmore Dishwashers
    Frigidaire dishwasher - no heat coming on to dry the dishes
    Did you ever learn why the heat was not drying dishes? We have the same problem.
    May 18, 2009 | Electrolux Frigidaire Professional Series...
    Dishwasher
    good luck
    May 09, 2009 | Dishwashers
    Dishwasher problem - no water in the tub
    hi.
    The sensore key that control the door of dish washer may be show that the door is open & it doesent let that water come to machine . you should checke the key
    Nov 09, 2008 | Frigidaire 24 in. FDB1250RE Built-in...
    Dishes won't come clean
    If you have dishes (typically cutting boards or really tall dishes) that block the dispenser door from opening, the water cannot wash out all the detergent during the wash cycle. Check to see that after loading the dishes, your detergent door has clearance.
    Aug 26, 2007 | Frigidaire 24 in. FDB126RB Built-in...
    Dishwashers Logo
    Top Dishwashers Experts
