Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Door will not support itself - Frigidaire 24 in. FDB126RB Built-in Dishwasher
2006 Nissan Quest back door won't open.
f you can get the door open, at the top left corner of the door is a bar that attaches to the door that opens and closes it by use of a motor. It may have loosened itself off. If you can't get the door open at all make sure there is nothing that may have closed on the door itself, If there is something there such as a strap or something you will probably be fighting with it for a while but eventually it should work itself loose. The bar from the motor that attaches to the door may have came loose. My quest is doing the same thing. I went to tighten it down and it had already stripped itself off of the inside of the door frame. I was able to get the nut by closing the door and digging for it inside of the door frame. Of course all of the door panels were removed to do this. On the downside of this the nut was tack welded to the inside of the door frame, there is absolutely no way to get this nut back up in there unless I cut a small hole in the door where I can get the nut in there to tighten down.
I will try to get to fix it tomorrow if I can, the problem is I'm going to have to fix it somehow or the back door will be useless unless I feel like opening it from the emergency latch every time I need to open it.
Sep 28, 2016 | Nissan Cars & Trucks
Dishwasher turns itself on and beeps periodically but does not start
Seems to be a faulty door latch...it wants to start but the computer thinks the door is still open and wont allowing it to continue, thus turning off. Try playing with the door latch before opening it up and looking within the latch.
Dec 02, 2013 | LG Dishwashers
2006 saturn ion dome light goes on by itself and
When this happened to mine it ended up being a bad door switch. The alarm, dome/map lights and electric door locks are all connected to the door switches. It cost $65 for diagnosis, parts and labor at Saturn of South Burlington VT
Jan 05, 2010 | 2006 Saturn ION
How to change drivers door latch on vw golf sdi 1999 as drivers door opens when driving
Have you tried using WD-40 to help the lock from sticking you may not need replace it.
However if you feel it's necessary ...you need to remove the inside door panel with the window up remove the two bars that are you inner lock and door handle levers a plastic clip holds them into place on the lock itself .a drop light is very helpful once the levers are disconnected remove the outer screws on the door itself the lock should fall off from the inside at this point ...install new lock and reinstall rods { levers} to the lock itself test before reinstalling door panel then secure when confident it works properly
Nov 25, 2009 | 1999 Volkswagen Golf
Oven door will not unlock after cleaning itself.
I've seen this before. Sometimes it is the temperature sensor of the oven itself - or the mechanical servo lockingthe door. If it is giving an error - it is the sensor. If no error - it is the lock itself.
Oct 10, 2009 | Whirlpool Accubake RF362LXTT Electric...
Garage Door Opens by Itself
It sounds like someone in the neighborhood has the same frequency as you do. Change your setting onyou Garage door opener and the unit itself to match, and your problem should go away.
Sep 23, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Dryer door opens by itself after a few seconds
If you are drying very large loads the door could be popping open from weight against it, not the most likely source of problem. Most likely latch is getting worn out and needs replaced.
Apr 26, 2009 | Dryers
Garage Door opens by itself
Your garage door springs may be out of balance. Try this test: Remove power from the opener motor. Pull the red release rope so that the door is detached from the openers drive. Lift open the door by hand- it should open all the way freely. Next, pull the door back down, stopping it about chest-high. It should remain where you stopped it. IIf the door is difficult to move, or does not stay half open, the springs need replacement or adjustment.
Aug 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
11 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
