Question about Imperial Toys Little Tikes Bubblin Leaf Blower
Bubble leaf blower wont blow bubbles
Ive put new batteries also new bubbles and it turms on fine but it will not blow gubbles
I have a BG55 blower when I try to prime it no gas come in bubble. I have made sure there nothing in gas line,and it skeet when I put a pin in the little hole, but no gas when u try to prime.
Apart from the bubble there is at least one non-return valve that could be stuck or not working because it is dry.
Could be removing the bubble and wetting everything thoroughly with fuel and quickly refitting it could kick-start it and make it work.
Sep 05, 2016 | Stihl Bg 55
One day after blowing i had to refill gas and the blower stopped and hasnt started since.
One thing you can check is the vent filter to the tank. It allows air in but no fuel out. It prevents vacuum lock. It is a hose attached o the tank. By the way, des the bubble primer work? If not that may be the problem as well.
Nov 29, 2015 | Garden
I have a weed eater brand blower and I can't get fuel to the bubble I have replaced the tube and cleaned everything but it's not helping, now when you put file to the engine via the spark plug it runs like...
The bubble allows you to squirt fuel into the engine to get it started then the main fuel jet takes over. Probably a crack on the bubble as it needs to create a vacuum to pull fuel in and then jet out
Dec 09, 2013 | Garden
My suitcase on petz5 wont let me put a bubble blower back its annoying and i want to get rid of it.Please oh please help me!!!!
Okay, get out another bubble blowing box, and then put the first bubble blower in the box with the second one. You can put two in one box and put them away together. Hope this helped!
Sep 28, 2011 | Ubi Soft Catz 5 (Windows) (680901) for PC
I have low compression. It won't start. Poulan Pro pbvm200le
rebuild time, assuming your low compression is verified by a compression check.
Dec 13, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have a huskavarna leaf blower 140 back pac i run it for 5 min then it srarves for gas let off on the throtle for 10 seconds put on full it gos to full rpms the starves agian
Carburetor may need adjusting or rebuilding. I would try mixing up some fresh fuel mixture and try that first. Use gas from the station not from the can sitting in the garage.
Good Day.
Oct 28, 2009 | Husqvarna Backpack Blower, Model No. 356bt
Fuel lines replacement
The larger of the 2 lines is the pick up/filter line - the smaller is the primer feed line that goes to the pressure bubble...The fittings are different sizes so it should be simple. To test it , with the hose out of the tank..press the primer bubble...it will blow air out of the line...
Apr 11, 2009 | Craftsman 4 Cycle Blower/Vac
Bubble will not stay full
If it's new then it should still be under warranty, I would bring it back and ask for an exchange or have them find a place that does warranty work on it. Once you perform anything on it your self that could void out any warranty there is on the equipment. If there is no warranty then I may be able to help you further.
Dec 18, 2008 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Imperial Toys Little Tikes Bubblin Leaf Blower Logo
Top Imperial Toys Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Imperial Toys Garden Expert? Answer questions, earn points and help others
