Question about Motorola Mobility H710 Bluetooth Headset
Heatset won't power on - Motorola Mobility H710 Bluetooth Headset
Need to reset plantronics voyager pro heatset it pair with wrong phone and i cannot reset it or know how
to reset or pair your bluetooth device you need to put the device into discovery mode.To do this most manufactures use the power button,by holding the power button down for 8 to 10 seconds while turning the device on it should put it into discovery mode.Usually a light will remain on then you can find or search from your phone for new device.Once your phone has discovered the device it will ask for a pin\pairing code .Once again most manufactures use a 4 digit pin\pairing code they are as follows,0000,1234,9999, or 1111,try them in this order one will work. Hope this helps
Mar 22, 2011 | Plantronics Discovery 925 Bluetooth...
My xbox was just working then i plugged in my turtle beach heatset and now it wont even turn on! :'(
Though I'm not familiar with this model of headset, it's likely that it could be drawing too much power from your 360 and it can't handle it. Do you have a fan connected to the back of your 360? Also, is it only a lack of power or are there other things going on, such as red lights? If there are red lights, this is a far more serious problem than a lack of power.
Mar 12, 2011 | Microsoft Xbox 360 Console
Can' find the pairing code for Q7 Bluetooth headset
The code should be 0000 or 1234.
Any further questions feel free to ask.
Correct? Good vote wouldnt go a miss ;)
Nov 19, 2010 | Cell Phones
How can i pair it with a at&t samsung solstice?
how to install applications in samsung sgh-a887 and what is the pass key to connect blue true heatset
Jan 30, 2010 | British Telecom Jabra BT2010 Wireless...
My motorola s9 heatset is not working with acer aspire bluetooth
Your acer does not support Stereo bluetooth. Its different from your common bluetooth headsets.
Jan 15, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
Dell dj
  • Try another heatset to be sure there is no output.
Aug 27, 2008 | Dell DJ MP3 Player
7373 Headset problem
just try a restart for your mobile. It should be solved by this. incase it is not helping try to reset to factory setting but you will loose your personlaised setting of the hone though.
Jan 11, 2008 | Nokia 7373 Cellular Phone
Format problem
Make sure u put enough volume to hear it. And check your heatset if its working. Try to put new batt.
Aug 04, 2007 | SanDisk Sansa m230 MP3 Player
Motorola Mobility H710 Bluetooth Headset Logo
14 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
