Question about Brother CS-8150 Computerized Sewing Machine
Bobbin winder shaft wont spin
How do I take it apart
  • 84 Answers
The shaft to the bobbin winder may be frozen. Add a couple drops of sewing machine oil then let the oil penetrate for about 5 mins. Get a pair of pliers then carefully and lightly turn the bobbin winder until freely moving. Remove the bobbin case, thread, and needle then let the sewing machine run freely with the bobbin winder engaged for about 15 mins.
Posted on Mar 25, 2015
I opened up my machine to find that the bobbin winder wheel (little black ring) had totally turned into black sludge in my machine. It is very gooey and hard to remove. I ordered the part from sewingpartsonline.com and replaced the ring. It is still not working..... ugh
Posted on Mar 24, 2015
    Novelist:
  • 268 Answers
If you take it apart, you'll void the remaining warranty. The usual cause is not getting the door open completely and/or thread wrapped around the spindle.
You'll also want to take a look at: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=CS8150
Posted on May 24, 2014
  • 16 Answers
SOURCE: Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Posted on Sep 27, 2008
  • 255 Answers
SOURCE: Bobbin winder does not spin
Hi. I have a CS-8060 and while I love the machine--the bobbin winder isn't my favorite. Anyway, I have found that the cover to the bobbin winder must be opened completely, also the thread spool must be as far back as possible. Another place I'd check is with a small flashlight just under the small bobbin spool. It can be hard to see under there, so a small flashlight helps. I have gotten thread wound around the pin that goes up to hold the bobbin and if sufficient thread has gotten up in there it could keep the spool from spinning. It's hard to clean out, but careful use of a seam ripper and tweezers does the job.
Good luck and let me know if this works.
Robbie
Posted on Jan 11, 2010
caroldon
  • 17129 Answers
SOURCE: bobbin winder won't spin Cannot load bobbin
Can be dirt or particles that have made it stuck with friction and so a resetting /overhauling with good oiling, degresing will resolve the matter, provided there is wearing off in the drive.
First use a degreasing spray before you can disemble.
Posted on Sep 30, 2010
SOURCE: Brother CS80 ..... bobbin winder
check the power cord to see if it plugged in to the machine correctly
& if it is then something could be loose or broken inside, it needs to be serviced
Posted on Aug 03, 2011
ju222dy
  • 8 Answers
SOURCE: Bobbin winder shaft won't spin. LCD says bobbin winding.
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Posted on Aug 09, 2012
Husqvarna viking 300 sewing machine bobbin winder will not stop spinning. machine will not sew when foot pedal depressed. bobbin winder just keeps spinning.
The bobbin winder moves a plate next to the handwheel that disengages the needle from moving If you can't push it back to the left you will have to take the machine apart to fix it.
Jun 10, 2017 | Husqvarna Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Did you find the answer? Had this machine over 10 years and no problem. Started with not filling bobbin but half way. Now it will not spin bobbin.
Sep 30, 2012 | Brother XL-2600
Sewing machine Singer Advance 7422, I try to fill a bobbin on the top of my machine. I put the bobbin in position and the shaft will not turn. The machine is treaded correctly and put in the right...
some machine, you have to push the bobbin winder spindle to the
right so that it will wind the bobbin, I have to on mine.
but if you've already done that then the machine needs to be checked
to see what wrong with the bobbin winder spindle
Aug 21, 2012 | Singer 7422
The bobbin shaft will not spin
make sure the bobbin winder spindle has been pushed to the right
if you've done that, & it doens't wind the bobbin then the machine
will need to be checked
Bobbin winder belt melted
Jan 18, 2012 | Brother CS6000i Computerized Sewing...
Brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Jul 17, 2009 | Brother CS-8060 Computerized Sewing...
Jun 16, 2009 | Brother CS-8150 Computerized Sewing...
Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
The winding sound is the rubber O-ring against the spinning pulley (back of hand wheel) - do not let this continue, it will wear out the O-ring.
I had the same problem and I found the shaft bushing of the winder dry and needed lubed. Use oil or spray lithium grease and it should work fine. Spin the bobbin shaft by hand (not the hand wheel) to get it freed up after oiling.
You can oil from the top and should take off the side case to clean the excess oil from the O-ring. The shaft bushing is a tight fit and any dry oil will get sticky and prevent winding.
Jan 22, 2009 | Kenmore Sewing Machines
Brother CS-8150 Computerized Sewing Machine Logo
321 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
