Question about Ricoh 965460 SPC220N Colour Laser SP C220N Refurbished Mfr P/N
Red alert light on ricoh printer
Alert light on
Red light of ricoh sp200 is parmanently on
  1. Alert Indicator
    This indicator lights up red when the machine runs out of paper or consumables, when the paper settings do not match the settings specified by the driver, or when other errors occur.
See page 12 on the link below http://data.manualslib.com/pdf3/61/6004/600310-ricoh/sp_200.pdf?97aa7364b3bed27ea4784c2ca038bf32
Mar 02, 2016 | Ricoh Office Equipment & Supplies
How do i fix error code 452 in Ricoh Afficio MPC2030
Paper transfer unit contact error
The paper transfer unit contact sensor does not detect the movement of actuator at the sensor while the polygon motor rotates.
?? Defective paper transfer unit contact sensor
?? Defective paper transfer unit contact motor
1. Check or replace the harness.
2. Replace the image transfer belt unit or paper transfer unit.
3. Replace the HVPS-TTS board.
Jan 29, 2016 | Ricoh Office Equipment & Supplies
How do I reset the alert light still on to off ? after refill black toner ?
Replace the chip, or mite have a RFID chip then you need a new cartridge
Nov 18, 2015 | Ricoh Aficio Sp C222dn Color Laser Printer...
Red light all time when ink is finished and refilled it.
Feb 25, 2014 | Ricoh Aficio 1515MF All-In-One Laser...
When switch on the printer indicates red alert Printer Model sp3410dn
You need to download SOM smart organizing monitor from ricoh website. you will see the error or error code.
Oct 28, 2013 | Ricoh SP 3410DN Laser Printer
Ricoh 3000dn
1. The cover is open.
• Close the cover.
2. No paper in the tray
• Load paper in the tray.
3. The printer has stopped printing due to a major error.
4. The print cartridge is not installed.
• Install the print cartridge.
5. The life of the print cartridge.
• Replace the print cartridge
Apr 15, 2013 | Ricoh Aficio Sp 3300DN Laser Printer
Ricoh SP C221n not printing test page
You can install the SOM (Smart Organizing Monitor), it is a utility which can check the status of a printer and set up a printer
from a PC. This utility is executed from a printer driver.
Start the SOM to see the status of your printer..
Apr 11, 2013 | Ricoh Aficio SP-C210SF Printer
Ricoh CL7200D Replace Fusing Unit (type C)
press the two arrow for 10 sec. hit enter you are in service mode
go to engine and diagnostic1 and sp7804 and go to 16
reset fuser change. enter
Jun 05, 2008 | Ricoh Aficio CL7200D Laser Printer
Ricoh 965460 SPC220N Colour Laser SP C220N Refurbished Mfr P/N Logo
155 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
