Question about Riccar 8850 Vacuum
Belt spins, roller does not
The roller beater bar does not spin with the belt
  • Riccar Master
  • 1,318 Answers
The belt has probably lost elasticity or the clutch needs adjusted or a new rubber pad.
Posted on Aug 11, 2014
4 Suggested Answers
SOURCE: Roller will not spin
Thank you a friend helped me find the problem. It was actually very simple!
Posted on Aug 29, 2008
  • 715 Answers
SOURCE: Brush/beater bar does not spin.
replace belt
Posted on Nov 01, 2009
SOURCE: My Riccar 8850 belt works but the roller will not spin
I see this same problem posted repeatedly here. The only solutions offered are to "change the belt". When most people state that they've changed the belt and still have the same problem the recommendation is usually "are you sure you changed the belt correctly?".
Bogus. This is a major design issue with the Riccar 8800 series vacuums. It has something to do with the roller and clutch assembly. Either people must replace these every 3-4 months, as they fail at a cost of $50+, or there is another solution and this solution is something other than "change the belt".
Posted on Mar 19, 2010
Beater bar only spins when vacuum is locked & upright.
Your belt is probably stretched and can't turn the brush when it's on the floor. Replace the belt at least twice per year.
Feb 23, 2016 | Bissell Pet Hair Eraser Bagless Vacuum
Kirby vacuum-The beater bar is turning, but the light is not on. Is something else wrong?
Check to make sure the magnet on the roller is on the side with the coil (this activates the light). You may have installed the roller with the wrong ends in the opposite sides.
Apr 11, 2014 | Kirby Vacuums
I replaced my Bissell vacuum cleaner belt with a Bissell belt. I ordered it from them so I know it's the right one. I replaced it and the roller won't spin and the belt smells like it burning.
Beckiande485:
You will need to unplug the vacuum from the wall, lay it down so you can see the bottom of the vacuum head and remove the bottom plate (foot plate) Probably philllips head screws. pull up on the roller (called the beater bar). The beater bar will come straight up. Disconnect the belt and check the fittings at the ends of the beater bar... I'll bet that they don't spin easily (The fittings have roller bearings in them, and the roller bearings get gunked up with hair, carpet fibers and dirt). Pull the end fittings off of the roller and remove all of the hair and carpet fibers off of the end of the beater bar and the fittings and out of the bearings. Check to make sure that the roller bearings spin freely. If they do not spin freely, put some rubbing alcohol in the bearing (you can pour it onto the bearing and spin the bearing manually until it spins freely, or you can use a spray bottle with alcohol in it as I do. Once the bearing spin freely, dry them out so no alcohol remains in the bearing, then a drop or two of light machine oil (3 in 1 oil will do) in each bearing and spin the bearing again to distribute the oil. Now would be a good time to check for any clogs in the vacuum head where the hose connects, and check the hose for clogs. Reassemble the beater bar and reinstall it in the vacuum with a new belt, reinstall the foot plate.
Your machine should run like new.
Feb 15, 2013 | Bissell Vacuums
Roller will not turn
Conmaur102:
I don't know what type of vacuum you have, but you should check the drive belt to see if it is damaged. Remove the sole plate (at the bottom of the head) and remove the belt and roller (called the beater bar). check the bearings at each end of the beater bar (they must roll easily and smoothly). If they are bound up, pull them off of the ends of the beater bar and remove the hair, strings, and fibers wound around the end of the beater bar. Lubricate the bearings with light machine oil, and spin them by hand until they spin freely. Reinstall the belt and beater bar, and reinstall the sole plate. While you are at it... check the hose and head to make sure they are not clogged.
Jan 06, 2013 | Vacuums
The brush on my Electrolux Versatility will not spin. You can spin it by hand, but the motor will not spin it.
Hello, W/D here.
Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized.
1. Turn off the power (unplug).
2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand.
3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc.
4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it.
5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
Best regards, --W/D--
Jan 29, 2011 | Electrolux EL8502 Versatility Bagless...
My vacuum has not been running right..the beater bar is not picking up and the rollers aren't spinning...the belt doesn't need replaced so what else could it be...everything else seems to be running...
The motor shaft that spins the belt may have hair wrapped arount it, causin the belt to slip. You can't miss the burnt odor.
Remove the belt and clean the motor shaft.
Sep 29, 2009 | Vacuums
My roller do not spin
There is also a circuit protector which trips if something gets caught in the roller, so that might be the problem. There is a very small red button on the right side at the bottom of the vacuum (IT'S VERY TINY), and you just push that in and it will reset the circuit.
Aug 22, 2009 | Kenmore 31913 Progressive Direct Drive...
New noise when vac is run
mine was allowing the roller/beater bar to hit the cover as it turned take the cover back off and ensure the beater is in the right place then that the cover is locked in the right place then you can spin it by hand (power cord unplugged of course) and make sure it is clearing everything. BTW, the belt has to be stretched to get the beater bar in place like on most vac.s
Jan 23, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a central vac. and the beater bar, for the carpet is not turning. the vacuum still sucks but the beater bar doesn't turn. I checked the belt it is fine.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=818384
Generic problem for all Vacuums
Posted by bmiller874 on July 22, 2008
I have a central vac. and the beater bar, for the carpet is not turning. The vacuum still sucks but the beater bar doesn't turn. I checked the belt it is fine.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Even though the belt looks fine it does stretch out and then it will not spin the brushroll @ the speed it is supposed to spin, there are 2 or 3 things to check. #1. The brushroll has be turning or spinning freely without the belt being on the unit. #2. The motor pulley has to be spinning freely as well #3. The belt needs to be changed every 4 to 6 months for the best cleaning and to store the extras belts in a Ziploc bag in the refrigerator. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. I am not sure what the brand name of the central vac is, and maybe next time you can include the brand name and model #.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 22, 2008 | Vacuums
Beater bar belt too loose
You need a new belt, they stretch after awhile and will slip.
Apr 07, 2008 | Vacuums
Vacuums Logo
97 people viewed this question
Top Riccar Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
