Question about Boating
How much does a 1995 18 foot tuffy renegade weigh
What does a 1985 scorpion 31 foot cc weigh with twin two stroke mercury outboard motors 250hp
LOL.. a whole bunch... why??
a pair of Mercury Pro-XS 250's weigh 1,100 lbs with props - dry
May 16, 2017 | Mercury Boating
Will 3.74cu.ft. freezer hold 95lb of food?
Hi Trish:
1 cubic foot of water weighs 62.4 pounds so if you had 3.74 cubic feet of water (not frozen) it would weigh just over 233 pounds.
Most of the frozen veggies you put in a freezer have air space and the specific gravity (weight per cubic foot) is quite a bit less than water. Meats are closer to the same weight per cubic foot as water, but you still have air spaces between the packages.
I'd guess that you could get 95 lbs of food in it but you would have to pack it very carefully.
May 18, 2015 | Freezers
Installing passenger foot pegs
Hi Yogamaster77, for more information about your question please visit the website below. Good luck and have nice day.
http://www.lehmantrikes.com/assets/dealers/docs/fxd-renegade-installation-instructions-cd2db383b4a8.pdf
Apr 01, 2012 | 2002 Harley Davidson FXDL Dyna Low Rider
My WW78 scale keeps giving an ERR message when I stand on it.
Usually I change the weight by weighing one foot and then weighing again with both. And then I keep repeating that until my results are consistent. Then that result seems to be accurate
Feb 19, 2012 | Conair Weight Watchers® WW78 by Glass...
I have a Renegade 200 and it Starts but won't
Try shifting into gear when the motor isn't running. If it goes into gear check your clutch adjustment; if the clutch remains partially engaged you wont be able to get it into gear.
Jun 26, 2011 | 2006 UM Renegade 200
I have a Troy Bilt Tuffy Tiller H30-35387S Ser 91330. The only number I can find for the tiller is on the shaft housing between the tines and the wheels and it is X0010527. I need a manual or parts diagram...
You've got the right serial number - it appears you've got one of the older Tuffy's. I'd suggest keeping an eye on Ebay for the manual you're looking for. I find them out there with some regularity. You can't get them from a dealer anymore because this Tuffy was sold by Troy Bilt before they went bankrupt and MTD bought the assets.
Jul 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Need a manual
here is the Tuffy webpage at the troybuilt.com... directly under the photo of the tiller is a gray "download manual" link...
best wishes,
k
May 28, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Need manual for a Troy-Bilt Tuffy tiller
Your engine number is wrong by only one character. The proper number is H30-35387S you had a 5 instead of the S. You can download the engine manual from Tecumseh. I don't know about The rest of the tiller. (I have the same tiller).
Feb 21, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Boating Logo
216 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
