Question about Casio Watches
Replacement watch band for Casio fishermans watch 2632
Having big problem to get info on where to purchase this
  • 4 Answers
SOURCE: how to adjust metal wrist band on casio watch?
  1. Pop out one spring pin to disconnect the band from the watch or from itself at the clasp. If you don't have a special tool for this, a needle or a pin will probably work. A straightened paper clip may be too thick, but they are cheap so you could try it. Now the watch and band can sit flat on the work table.
  2. Examine the links. If some of them have little arrows on them (usually the ones closest to both sides of the clasp), they are removable.
  3. These removable links are held together by a "U" shaped (actually a squared off "U" - sort of like this |_| ) pin that is inserted into the link. There may should be some kind of window-like opening in the link into which you can insert a narrow screwdriver or similar tool or even a small nail (around 6-penny size) and push out the |_| shaped pin. A straightened paper clip is probably not sturdy enough, but you could try it. Push in the direction of the arrow (from tail to point). The links that were joined by the |_| pin can now be separated.
  4. Remove a second such pin from another adjacent link. Now a single link is free and can be discarded (or kept). Reconnect the remaining adjustable links with one of the |_| pins and re-attach the spring pin from step 1 so the band is reunited with itself or with the watch.
  5. Try it on. If it is still too long, repeat the process. Good luck.
Posted on Mar 24, 2009
  • 12 Answers
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Posted on Oct 04, 2009
escapement
  • 2334 Answers
SOURCE: need to adjust length of watch band: Casio WV-57H
Check out my TIPS here and you will find out how to do that
Posted on Feb 05, 2010
  • 101 Answers
SOURCE: My Casio watch band has split apart where the
are you referring to casio mtg900 if so do you mean the rubber part below the G button . If so I do believe casio sells that first link . You can call them if you would like to order it if they still have in stock or for a whole new band
you can see the parts store here
http://www.pacparts.com/model.cfm?CFID=3663724&CFTOKEN=19469938&mfg=CASIO&model_id=MTG900DA-9V&row_start=1&src_model_id=mtg-900&action=list_part
I believe the 12 h and 6 h are the parts you are looking for I am not sure what side you need 12 oclock or 6 oclock , but give them a call they should be able to help you out
the other company that handles watch parts is here
http://www.americanperfit.com/parts/parts.htm
Posted on Oct 26, 2010
vetteman3002
  • 2299 Answers
SOURCE: I need to find a
Here is one. You are right. They are very hard to find a band. I found lots of watches. But the band by itself is very difficult to find. But here is a link to one that I found. It shows in the picture with a watch too. But it is for the band, tools to change it and instructions. Here is the link.
http://www.squiggly.com/us/en/swatch/white-ceramic-strap-ayls141g.htm
Posted on Dec 14, 2010
Where can I get a replacement band?
Ebay is a great place for special watch bands. this one is $30:
http://www.ebay.com/itm/CASIO-SEA-PATHFINDER-WATCH-BAND-BLACK-SPF-40-/330812864375?pt=LH_DefaultDomain_0&hash=item4d05fbb777
You can also go to the source, Casio, and purchase a new band:
http://www.casio.com/support/buyparts/
Oct 18, 2012 | Casio Sea Pathfinder SPF70-2V Wrist Watch
Casio Fisherman (PAS400B) watch replacement clip for spring pins
mcdevito75 here, I'm surprised a jeweler couldn"t help. Here is Casio"s contact number, speak with them, TIP, get a spring bar 1/2 MM smaller and larger than what you measured. Contact Casio at 800-435-7732 9AM-----5 PM EST. hope this helps.
Aug 03, 2010 | Casio Forester PAS400B-5V Wrist Watch
BG1301 Casio watch replacement band
Go to "casio.com" and click on "support".
Although they don't say so directly, their repair section imply that they can replace straps.
Jul 20, 2010 | Casio BG1301-4V Pink Baby-G Watch with...
Problem with WAVE CEPTOR watch band
http://world.casio.com/wat/download/en/manual/
There are so many applications use of the manual will be mandatory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
May 06, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio G-Shock GW-300 replacement bands
I have a Casio g-shock gw-330a and now find myself again replacing the band. So far, $60 on bands. They last me two or three years. To install the band, take the band and watch to a Jeweler. My local Sears does it for me. $5 for installation; $5 for purchase shipping; $20 for band. $30 every couple of years.
This cost disturbs me.
Jun 09, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
3747 Replacement Watch Band
Use this link to get in touch with Casio:
http://www.casio.com/home/
Choose relevant application under the SUPPORT. Here you can find Technical Support, Casio Parts etc.
Choose your nearest region and ask to supply new watch band.
Do not forget to rate, please.
Jan 13, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Wrong Manual Received for CASIO Pathfinder PAS 400B 2632
I was having the same problem, so I went to casio.com and looked for their manuals for watches. I ended up finding this page:
If you enter the number from the back case of the watch, (in this case, the PAS 400B is 2632) and it will allow you to download the manual from their archives in a pdf format.
Hope this helps!
Jun 10, 2008 | Watches
Watches Logo
57 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
