Question about Polaroid LCD-2050 20 in. Television
White screen no picture
TV turns on but as soon as its on screen turns white not even displaying Polaroid symbol. What could be problem?
3 Suggested Answers
panchal643Ja
  • 243 Answers
SOURCE: i have a polaroid lcd tv and when i turn it on the
Remove all connector of all Board (Mainly Mother Board)and clean and fix it properly
Posted on Jan 21, 2010
  • 9 Answers
SOURCE: i am getting a white screen (no picture) on a polaroid LCD
People any lcd tv with a white screen cause by the T-con board if you have some experiences you can check with a multimeter the (smd) fuse on the T-con board it is right in de middel on top in the back of the tv. you might have to move some of the boards to get to it. if the fuse is broken replace it with another smd fuse otherwise relace the t-con.
Posted on Nov 01, 2011
My screen is white I can barely see any pictures rest everything and turn the tv off and on please help
T'Con board fault. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 07, 2015 | Polaroid Televison & Video
How do I fix the white screen on my Polaroid Tablet S7? I cannot get the screen past the white.
either a virus, or something has become loose inside (dropped it and the LCD connector is out).... Google "screen replacement video" and see if you're brave enough to check.
Jun 24, 2014 | Polaroid S7 7-in. Internet Tablet
Our lcd phillips tv screen turns completely white after about an hour of use
The TV, most probably, the display circuit or the display itself has developed dry solder/components leaking and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Philips Televison & Video
My screeen has gone white on my tv how do i fix it on my element flx-2210 tv
White screen only / no picture is a sure sign of a failure in the power supply board. Your TV is getting power to the back lights but the control board voltages are not getting through so it is not displaying the picture right. This is an easy repair to do, you will just need to replace the filter capacitors on the power supply board. This Element model is actually made by Funai and is the same as the Polaroid FLX-01911c TV. Here is a repair guide for that model that will show you what needs to be replaced to get your TV back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps you out.
BuddyMc
Jan 30, 2011 | Element Electronics FLX-2210 22 in. LCD...
It is model FLM 9011 SCREEN GOES COMPLETELY WHITE
my dynex tv went white and the pictures are white with very little color I tried everything what should I do? should I levae the tv on?
Dec 30, 2009 | Polaroid FLM-2011 Television
I am getting a white screen (no picture) on a polaroid LCD
Jun 28, 2009 | Polaroid FLM-1911 19 in. LCD Television
Screaming static
Try turning off different lights near the room or in the room that it is in. Our tv does that if the overhead light in our bedroom is on, it's a room right next to our living room.
Jan 14, 2009 | Polaroid 4226TLMB 42 in. LCD TV
Sound, but no picture
Initially, this would either be a defective LCD panel or its interface. A way to verify is to play the portable DVD using an external video monitor such as your TV. If still gray or blue screen (no video) even in the TV/monitor, then it would be the video interface/circuitry. If the video is displayed, then it would just be the LCD panel display.
If it turns out to be the LCD display, it is very possible that it is a backlighting issue. Most likely, it would be in the inverter and/or CCF (cold cathode florescent) lamps. This is a relatively easy repair by re-soldering. It is perhaps more of a task to open the panel lid/cover of the LCD display.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 30, 2008 | Polaroid PDV-0701A Portable DVD Player
Polaroid LCD-2050 20 in. Television Logo
16 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
