Question about Kenmore 67082 Electric Dryer
Error code New (just out of the box) Kenmore HE5 110.8708 electric dryer.Installer got an F 70 code and said someone will contact next week.What is this code and can it be reset or does it mean it needs returned for another?Mike in Pa.
  • 1 more comment
  • Tile Doc Oct 27, 2007
    thanks
    Just discovered that the moron who installed it today wired it wrong.  Did not move the white wire from the green ground screw to the center wiring screw.
  • Anonymous Feb 11, 2008
    In my case I was the moron! Thanks for the info!
I had to open the top of the unit off and unplug the wires at the top left of the unit that went to (really cannot remember what was there but it's the only thing there) >
It had a white little plug.
When I plugged this back in the code went away.
I was told the code is (was) in the computer to SHUT DOWN because it was not properly grounded, and unplugging the above described erased the code.
No problems since Oct.
TileDr.
<a rel='nofollow' href="http://www.Tiledr.com/">Tile Doctor</a>
Posted on Feb 24, 2008
Well, I've read the manual inside/out & am certain that I have corrected the installers wiring properly - per the 4prong Nema 14-30R instructions.
1. Green wire to the dryer frame green screw location
2. Relocated white to the center screw terminal tab along with the white wire from the chord.
3. The remaining two (red & black) to the outer terminals.
I AM STILL GETTING THE F70 CODE AFTER A PERIOD OF TIME/USAGE. (well my wife is and it's driving me crazy)
I've checked the outlet (I happen to be an electronics eng.) - all checks well referenced to ground or neutral, etc....
The only other thing is possible damage to the chord, receptacle or dryer during usage while improperly wired.
The one thing I noticed is that when it was wired improperly the drum seemed to be turning slower, don't know really.
BUT DOES SOMEONE HAVE ANY SUGGESTIONS?
Mike in Austin - otherwise I'm calling Sears tomorrow to pick up their equipment for a refund.
Listen, I can't thank you all enough! Same problem - neutral white had not been relocated to center terminal (for a 4 prong 2 phase installation) and the green was - of course well you know that already.
This was unbelievably the 3rd dryer delivered;
1st. Had a creaking sound and was damaged on delivery
2nd. Actually had a beat to it - thumping-installer told me all dryers make sounds - I pointed out 'quietpack' to him, but well not sure if he understood.
3rd. WELL, THIS IS THE ONE WHERE THEY WIRED IT WRONG. Mike in Austin
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Kenmore 70 series dryer squeaked, heated, drum turned, then turned off and won't come back on--is it toast or worth fixing?
It all depends on how you look at things.
Comparatively speaking, dryers are a piece of cake.
However, with out mechanical ability and tools, it could be over your head.
You decide.
If you choose to fix it yourself, it could be done for a few dozen dollars.
Hiring a repair man could make it cheaper to buy a new one.
New parts are available through "Sears parts" on the internet.
Someone will need to take it all apart to see why it stopped on you. To do it yourself, you may also need an electrical testing meter.
Be blessed.
Mar 20, 2013 | Kenmore Dryers
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 24, 2017 | Kenmore Dryers
Kenmore electric dryer heats but does not dry the
Hi, Here are the obvious parts to check: Heater, High limit, Thermal fuse or thermostats...these are all generally located in the back but some models you access them from front. the most common cause is either heater or thermal fuse, I will include a picture of the thermal fuse. If you test these parts and find they all work you may be looking at a centrifiacal switch problem.
Here is a picture of the thermal fuse check this part first:
http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
Please feel free to contact again if you have any other problems.
Hope this helps.
Jun 23, 2009 | Kenmore 63942 Dryer
Kenmore series 70 electric dryer will not heat up, but will rotate.
remove the back cover and check the heater box fuse and the heating element,do you have a meter?
May 10, 2009 | Dryers
Kenmore he3 electric dryer has F1 error code while drying clothes. dryer will run for a few minutes and automatically shut off. purchased a new thermostat but can not find where the thermostat is located...
How to disassemble a kenmore dryer to get the drum out. Can someone tell me please. I want to know what I need to take off first so I don't mess anything up.
Jul 10, 2008 | Dryers
Kenmore 70 Series
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
Jun 04, 2008 | Dryers
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer error
Based on my brief internet research on this issue, after recieving the same error code, it appears to result from a communication issue between the electronic systems of the machine. Personally, I'm returning mine. Too many posts about this error.
Jun 30, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 67082 Electric Dryer Logo
110 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
