Question about 350 HV ESP Security System 350HV ESP
Valet mode Cannot find valet button. Everything works except no chirping. I forgot the alarm was set and opened my trunk. Alarm went off and I just pressed something on the remote to make it stop. Don't know what I pressed or what happened
  • 12 Answers
SOURCE: problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
Posted on Jan 15, 2009
SOURCE: need to disarm the alarm because the remote is not
i have an 02 WRX my alarm keepes going off and i cant start my car and it keeps honking and honkin this viper system cam with the car n there is no button to press my blue button is flashing n my car is honking loud ! help! RPN 473V
Posted on Oct 10, 2009
  • 128 Answers
SOURCE: I brought a car that has a clifford matrix 10.5
the reset button is under the dash somewhere. Different installers like to hide them in different spots look in the kick panels or just get in there with a flashlight I've had installers put them pretty far up there. just make sure you don't pull on any wires.
I have also seen an installer put the switch in the glove box so give that a shot as well.
Posted on Jan 25, 2010
  • 6 Answers
SOURCE: would like to know what the bottom 2 buttons mean on Viper 7153v
the bottom button is for function shift, and is used (with aux button) to activate certain functions (add on optional features like trunk pop, window roll up/down, rear defroster, etc--all depend on car and install) or by itself for status updates (interior temp check-press once, release, press and hold; remaining runtime-press and release three times, press and hold; lock status-press and release twice, press and hold). it is also used with lock and unlock for silent arm/disarm, and also to enter valet mode.
Posted on Feb 22, 2010
  • 643 Answers
SOURCE: VIPER 791xv. I lost the
Open the door, key to ON position,within 5 secs press the valet button one time, then press AND HOLD it the second time. While holding press the Lock button on the spare remote. Let go and turn off the car...your done.
Posted on Nov 11, 2010
Open trunk without key
Unlock door with valet key to shut alarm off and remove the trunk release switch. Jump the trunk switch wires together for a second and it will open
Mar 09, 2014 | Ford Thunderbird Cars & Trucks
Autopage xt74 alarm in silent mode
The only reason that your alarm would not chirp when locking and unlocking the doors is that the system is in valet. A visual notification that the alarm is in valet mode is the LED light is on solid. If the LED is on solid and you wish to make the alarm active again, turn the ignition on then, press and hold the valet/programming switch for two seconds. The LED light will turn off.
If the LED light is not on solid then, the issue may be with siren itself.
Sep 25, 2012 | Megatronix - TW71 - 5 Button 2 Way LCD...
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Jul 16, 2011 | Prestige Appliances Vehicle Parts &...
My avital alarm does not chirp anymore and it is just a solid light on the alarm light
With your drivers door wide open and no key in the ignition, press the remote control buttons.....lock-unlock-lock....within one second and the alarm will come out of valet mode, which it's currently in right now.
Jan 26, 2011 | Toyota Tacoma Cars & Trucks
How to turn kill switch off and see manual and instructions
I am assuming that you want to disable the system temporarily by putting it in valet mode. You will need to locate the valet button; they are usually installed under the dash within reach of the driver. The button should be black and about 1/2" in diameter.
Pressing and holding the button for 3 seconds while the alarm is disarmed will put the system into valet mode. The system will turn the LED light on steady and chirp the siren to indicate that valet mode has been activated. To exit valet mode, press and release the button. The LED will turn off and the siren will chirp to indicate that you have exited valet mode.
The included link is for the manual, see page 8.
http://www.caralarm.com/manuals/K-9/K9-Mundial-ss.pdf
Nov 03, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
The alarm is on a 1996 f150 the alarm will not chirp the led on truck is solid it isnt blinking and it is a 5701 viper
Your alarm got put into valet mode some how
.It's easy to reverse out of it back to normal. First look for a small black push button under the dash somewhere. It's called a valet button. Here are the steps.
1. open door
2.turn key on then off
3.then within 10 seconds hit that valet button once(your alarm light should be off. Tell you arm it again. Then it will blink)
Hope this helps
Aug 18, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Alarm is stuck in valet mode
This will work for many alarms, but not all:
Locate valet push button, may be hidden on or under dash somewhere. Turn on ignition, doesn't have to be started. Then push and hold valet button for a few seconds. Most alarms will chirp to confirm operation was a success.
DEI products require a slightly different procedure, and drivers door has to be open.
Some can be done through the remote.
Model of alarm will help alot, or FCC ID from back of remote. DC
Nov 04, 2009 | Vehicle Parts & Accessories
The alarm doesn't chirp and no flash of my headlights anymore. Also the blue light stays on the little receiver/antenna on the windshield wheather it is locked or not. What is the problem?
sounds like the alarm went into valet mode. that's usually what a solid blue light means on most viper alarms. check your owners manual on how to take the alarm out of valet mode. with the 5701 alarm its usually done with the remote. hope this helps
Aug 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The car arms but the alarm does not chirp
try turning your key on and flip the valet switch, your alarm is most likely in valet mode (youll know cause the led stays on) if that doesnt work, turn the key on and off then toggle thye valet switch 3x and that'll turn off silent mode. Good luck, Martin @ lessco electronics
Feb 25, 2009 | Car APS25CH Prestige 2 Button Remote...
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Sep 28, 2008 | Car Audio & Video
350 HV ESP Security System  350HV   ESP Logo
24 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
