Question about Bobcat Miller 225 Welder Generator 907209 Or 907210
F1 fuse replace - Bobcat Miller 225 Welder Generator 907209 Or 907210
Why the fuse burn and the car turn off , I change the fuse and the car turn on again
It sounds like a dead short somewhere in the ignition circuit or the "main" circuit. If everything else on the car dies (lights, chimes, instrument panel, etc) when that fuse blows, that would most likely be the main fuse you've identified. It's going to be a serious pain to find that short, and I'm sorry I don't have any real leads as to what it could be other than tracing the wiring back. Whatever you do, DO NOT replace the fuse with one of higher amperage... The wiring will surely melt or even worse, catch fire!
May 05, 2016 | Suzuki XL7 Cars & Trucks
F1 Blowing after replacing RCA cable Technics
ability to switch between 110 and 220 voltages. is it set at the wrong setting to power on? why did you need to replace inside wires? maybe something was touching inside and has blown the fuse. see legitimate repair shop.
Sep 11, 2012 | Panasonic Technics Sl-1210 Mk2 Turntable...
No spark
Check fuse F1 and if open replace it.
Fuses F1, F2 located on bracket behind left side panel.
Check your machine owner's manual on chapter 8-7. If you don't have it, here it is just follow the link below...
http://www.millerwelds.com/om/o4436p_mil.pdf
If this was useful to you please vote. Thanks.
Feb 19, 2011 | Miller Bobcat 3 Phase Welder Generator...
What fuse controls heater panel
there is many fuses that work different parts of the heater controls, in the battery fuse box (under the hood) fuses (f1-8 30 amp)( f1-9 20 amp )(f1-15 10 amp)(f1-64 40amp) and in the central junction box (inside the car) fuses (f2-36 7.5 amp) and fuse (f2-45 7.5 amp) all these fuses control functions of the heater control hope this helps you out . please leave feedback
Dec 29, 2010 | 2003 Ford Focus
When i put my ds charger in it gose red for one second
Sounds like your F1 fuse has blown. This fuse is located inside the DS lite and is very small (the longest side being less than 2mm long).
I would suggest that if you have a warranty that you send it off.
If you don't have one then there are plenty of repair services avaliable on the internet such as ebay.
If you have the skill and time to replace the F1 fuse yourself then there are a few items you will need:
A soldering iron ad solder,
A replacement SMD 0603 1A fuse (ebay have these, search F1 or F2 fuse),
A triwing screwdriver (found on ebay, search DS lite triwing screwdriver).
A precision crosshead screwdriver.
If you would like a guide on how to dismantle the DS lite and the location of the F1 fuse then click on my name and you will find the relevant guideson my profile page.
If you need any further help or advice please feel free to contact me.
Regards,
SOD69
Apr 11, 2010 | Nintendo DS Lite Console
It displays F1 . Is this a fuse problem and where is the F1 fuse
HELLO THERE
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Feb 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Maytag electric range shows F1 error message and beeps every hour or so. we've checked the fuses and they seem okay.
F1 code means a defective touchpad or membrane, usually the touch pad. Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1: Disconnect the power to the range
Gain access to the back of the ERC (clock)
Unplug the touchpad ribbon connector from the clock
Make sure everything is clear & will not short out when the power is turned back on to the range. Replace any covers removed to gain access to the ERC.
Turn the power back on to the range
Watch for the F1 and listen for the beepIf you get the F1 and beep, replace the ERC (clock)
If after approx. 60 min. you do not get the F1 fault, replace the touch pad. Note: some ranges incorporate the touchpad and the clock as one part so F1 means a bad clock control.
Nov 12, 2009 | Maytag MER5770 Electric Kitchen Range
Backenlight inverter panel failure formac gallery 1900 oxyg
mine had the same problem, replaced the fuse with a T2.5 amp.
Ammeter gave a reading of 1.6A across the fuse pads so we shall see if its pops...
Aug 01, 2008 | Formac Gallery 1900 Oxygen 19" LCD Monitor
Bobcat Miller  225 Welder Generator 907209 Or 907210 Logo
Top Bobcat Welding Tools Experts
Troy
Troy
Level 1 Expert
Lawrence Oravetz
Timllfixit
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
