Question about Dirt Devil Hoover Uh70085 Pet Cyclonic? Upright Vacuum
Beater bar in Hoover wind tunnel not spinning
I replaced the belts.. The suction is working but the beater bar is not spinning
reddevil6
  • 1673 Answers
SOURCE: I have cleaned all of the hoses...replaced the belt ...
Check the inlet down by the brush roll, it is probably clogged. You might change the belt also if you never have, I am sure it is stretched.
Posted on Jan 22, 2008
reddevil6
  • 1673 Answers
SOURCE: "brush bar spins erratically"
Belt needs to be replaced, it has stretched to the point that under load, it won't turn the brush roll like it should, so I would advise replacing the belt. And while you are doing that, check the brush roll and make sure the ends turn freely, if not, then replace it also. Then check the dirt inlet while you have the brush roll out.
Posted on Feb 29, 2008
SOURCE: Dirt Devil Featherlite - how to remove the beater bar to clean
If you lay it down and look under the base- by the brush roll- there are three screws you have to remove w/ a philips head screwdriver to get the base plate off. From there you can take out the brush roll, etc.
Posted on Mar 15, 2009
  • 60 Answers
SOURCE: twirly thing under the vacuum has stopped spinning
there is a belt that drives the beater brush. flip the unit over, you can remove the bottom cover by removing a couple of screws. to one side of the brush you will see a channel where the belt should be. go to you local walmart, sears or hardware store and in the vaccume section they will have belts, on each bag of belts will be a list of vaccumes that belt fits simply find yours. with the new belt simply lift the beater brush out at the belt channel side and install the belt around motor shaft and brush. then place brush back in place , be suer brush guides are in properly. this should do ya.
Posted on Aug 18, 2009
Testimonial: "Thank you so much!! I did try to take the bottom off my vacuum earlier and could only find one screw so I didn't want to break it. Will try again! <3 "
SOURCE: Hi My Hoover wind tunnel
If the motor stopped running, it most likely did because it was not being cooled, becuause something was stopping up the air flow. If you have cleaned the secondary filter out and it still stops while running, then remove the exhaust filter cartridge and try it then. If it does not stop running now, then the problem is the previous models like this had a foam filter as the exhaust filter, not a heppa cartridge filter. You will not hurt the machine by running it without the heppa cartridge. Cut a foam filter to fit to replace it. I do not think Hoover knows this yet.
I have a customer working on this problem today (Sept 2010) I have repaired machines for 30 years. This filter is meant to just catch the tiny particles from getting back into the air. However, it worked fine on the previous machines with the foam filter here instead of this Heppa cartridge.
Dave in Texas
Posted on Sep 09, 2010
Where is belt located on Hoover wind tunnel vacum. And how to replace it. My brushes are not spinning.
Its usually located underneath the body of the unit, turn it upside down and you should see the beater brush. You need to open the bottom cover to get at the brush and drive belt.
Mar 25, 2015 | Hoover U8126-900 Wind Tunnel Dual V...
Brush not spinning on my montiss turbo 850 vacuum. Hoover suction ok. Have took apart and deluded and still not working
Check the belt. If the beater bar will spin with the belt loose but not spin under power, the belt may be slipping.
Jan 28, 2015 | Hoover Vacuums
Do Hoover wind tunnel belts stretch?
Yes; and need to be replaced when they so streach too far. Usually caused by something getting stuck in the beater bar.
May 27, 2014 | Hoover Vacuums
Beater bar isn't working
Sounds like a broken belt. Unplug it flip it over and look at the bottom there is a cover over the bottom and the beater bars look for screws or levers to remove the cover then replace the belt. it goes around the beater bar and a drive shaft. check HERE for a manual and belts.
Jun 23, 2011 | Hoover Company Wind Tunnel U53019 Upright...
When using my hoover wind tunnel the last few times it has emitted a burnt rubber smell so my husband checked the belt and is wasn't broken or off but now when I use the vacuum the beater bar doesn't seem...
i take it the belt was put back on !! i would say hubbi forgot the tension arm a little black striker that can go in two ways but put in back wards it will not tension the arm
Jan 03, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Replacing a belt Hoover wind tunnel
You will find four screws under the bottom cover. remove these. remove the beater bar, loop new belt on bar on pulley area. install the bar and then pull the belt over the motor shaft. re-install cover.
Oct 05, 2009 | Hoover Vacuums
Self Propel wheels not enough power to move machine over carpet.
Sounds like the transmission might need an overhaul. Take it to a local vacuum repair shop and have them look at the transmission.
Sep 03, 2009 | Vacuums
Low suction
Hi, You can take care of both things at once. Here's how:
Unplug and flip your vacuum over, beater bar side up. Remove the cover base plate that surrounds your beater bar. It's held on with either clips or screws, and usually "hinges" toward the front of the vacuum to release when the clips/screws are undone. Remove the base plate. The beater bar sits in sockets where it fits into the vacuum. Pay particular attention to how it comes out as you remove the beater bar, so it will be much easier to put it back together. If your belt is good, it will want to come off with the beater bar, but will remain attached to the motor. If necessary, slip the belt off of the beater bar. Behind the beater bar, you'll see a cavity. This is where the vacuum pulls the dirt from the beater bar. Look up into the cavity; stuff almost always hangs up in there. Remove any debris that you can find. While you have your beater bar out, look at the ends, where it fits into the sockets. Hair and other material catches on the beater bar and winds around it. If it is in and around the sockets, it causes the vacuum to have to work harder to clean. Remove any debris that you find on either end. Get your new belt and place it on the motor shaft. Slip the beater bar into the belt, and install the beater bar and sockets back into the vacuum frame. It takes patience so don't worry if it takes a few tries to get it right. Once in, test your work by revolving the beater bar a bit with your hand. You should be able to feel the tension of the belt as it turns the bar and the motor shaft. Take one more look at the sockets, just to be sure that they are in the proper place, and that the beater bar is level in the frame. Reinstall the base plate. This should have you finished at this end.
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Aug 01, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Hoover U6476-910 - Very little suction from the bottom
If you haven't already, remove the beater bar. This is accomplished by unplugging the vacuum and turning it beater bar up. Remove the clips or screws that hold the plate on the beater bar and set aside. The beater bar sits in sockets, so carefully remove the bar, noting the correct position of the sockets. This will make reassembly much easier. Slip the beater bar out of the drive belt. Now, inspect the suction cavity that the beater bar would discharge into. Usually, things clog up here as there is a flex hose that catches things, creating a pluggage.
Hope this helps, --W/D--
Jul 18, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Dirt Devil Hoover Uh70085 Pet Cyclonic? Upright Vacuum Logo
20 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
