Question about Engine oil level. Sensor. Switch. . Allure, Lacrosse, rainier
Where is oil sensor on 2005 buick lacrosse?
Oil pressure sensor not working after oil change
Keith100881
  • 74 Answers
SOURCE: remote for buick Lacross doesn't work, battery new. Can't figure how to reset it.
have to be reset by dealer usually 20 to 35 dollars to do so
Posted on May 16, 2009
  • 192 Answers
SOURCE: lowbeams headlamp won,t work on 2005 buick
Start simple. Investigate your fuses, since it is unlikely, but not unheard of, for both low beams to fail simultaneously.
Do you know where your fuses are?
Posted on Aug 17, 2009
  • 7353 Answers
SOURCE: how do i change the low-beam bulb on my 2005 buick
there should be 2 brackets at the rear of bulb housing, 1 may have a small bolt.....lift these up and the headlamp housing should come out. you will see how it works when you get it apart.
Posted on Oct 09, 2009
  • 6 Answers
SOURCE: My remote won't start my 2005 Buick LaCross. I
Both my remotes no longer work. I will be ordering new ones off Ebay and having my dealer program them. New ones from Buick are very pricey.
Posted on Oct 20, 2009
  • 3 Answers
SOURCE: how to install/change complete headlight assembly
Buick Lacrosse - The bright light fitting is the same as the dim so take it apart first to see how the cover screws off/on and the light comes out. Both the cover and the bulb are removed by a standard twist to the counterclockwise and replaced by a twist to the clockwise. Now to the dim light. You have to release the entire light assembly before you can remove the screw-on cover to reach the light. On the rear edge of the light unit closest to the engine is a white locking tab. Pull that tab up just to the point where it releases…pull too far and it locks again. Next, locate the other locking bracket which is a metal bracket in the center-rear of the light assembly. This bracket is held down by a screw. Remove the screw with a 10mm wrench. Lift the bracket just like you did the white bracket. You should now be able to pull (or pry) the entire light unit forward a little. Depending on the size of your hands this might be enough. If not, then you need to release the plastic bumper assembly to give you a little more space. This is done by removing two expansion locking pins, one that holds the little plastic strip down between the bright and dim lights and one that is located inside a rubber bumper on the engine side of the light unit. To remove these locking pins, pull or pry up the little tab in the center of the pin just like you were pulling a nail by the head. That should give you more space.
Posted on Apr 03, 2010
One high beam not working 2006 Buick lacrosse
Sampson, sounds like a bunt out bulb, which will need changed.
If you feel comfortable doing it yourself. Basically three screws, and you have to pull one plastic fastener from the fascia (bumper) and pull the bumper back a bit, and pull the assembly out. I believe it is in the manual, not bad to do. I will post a link to tell or show you how to do it. Press the helpful button
Headlight Change 2005 2009 Buick LaCrosse 2006 Buick LaCrosse CX 3 8L V6
2008 Buick LaCrosse Headlight Replacement
Thread how do replace the headlight bulb in 2005 buick lacrosse
Headlight Bulbs
Feb 13, 2016 | Buick Cars & Trucks
Check engine light
I would check my oil level again, if it is good, then maybe your oil pressure sensor is bad or loose at the connector. They may have forgot to tighten your drain plug securly.
Dec 12, 2013 | 2005 Buick LaCrosse
My oil light is flashing red and making a dinging noise
Could just be out of oil. Check the oil. Don't drive it! If it has plenty of oil the oil sending unit maybe faulty.. Best have a shop check engine oil pressure with a mechanical oil pressure gauge before driving it.. Engine will be ruined if you drive it with no oil pressure.
Sep 16, 2011 | 2005 Buick LaCrosse
The car seems it runs out of gas after running for about 1 hour it first start doing this when the tank got just above 1/4 tank now when its between 1/2 and 3/4 tank
I am betting it is the fuel pump, fuel tank pressure sensor, fuel pressure sensor, fuel pump relay or a combination of these.
Check the following:
Cooling system working properly including fans.
Under hood fuel lines, touching coolant or heater hoses.
Fuel lines under vehicle close to or not shielded from exhaust pipe, converter, muffler. Fuel lines pinched or crushed.
Fuel filter changed recently.
Fuel pump pressure.
Aug 28, 2011 | 2005 Buick LaCrosse
Power steering leak at pump
These pumps are known to blown out the front shaft seal. But your problem is at the high pressure line. Remove the line and buy a new teflon seal or o-ring. Don't over-tighten!! The torque specs on these are pretty low and most people overtighten and crack the seal.
Jul 05, 2017 | 2005 Buick LaCrosse
Little heat in car
try changing antifreeze you may have whats called vapor locked wich prevents coolant from circulating
Feb 14, 2010 | 2005 Buick LaCrosse
How To Reset Low Oil Level Light On 2005 Buick Lacrosse
there's no reset for that. Vehicle might need a new oil light sensor
Nov 28, 2009 | 2005 Buick LaCrosse
Engine oil level. Sensor. Switch. . Allure, Lacrosse, rainier Logo
264 people viewed this question
Top Buick Vehicle Parts & Accessories Experts
Marc Taylor
Thomas Perkins
Thomas Perkins
Jeff Turcotte
Jeff Turcotte
Are you a Buick Vehicle Part and Accessory Expert? Answer questions, earn points and help others
