Question about HMF Exhaust Honda Rincon 650 03-05
My 2003 honda rincon does not seem to be charging but it shows it is charging. New battery but after 2-3days won't start
My 05 Honda rincon won't start at the button, I replaced the selenoid starter and new battery press the start button and nothing happens.
1. Make sure you have all the switches in the right place (kill switch..etc..)
1. With the key off - Take a screwdriver and jump the two big threaded connectors on the solenoid - the engine should turn over... if it doesn't - either the solenoid is bad -or you have no connections to the battery and/or starter. If it turns over, now turn the key on and see if it starts.. it should.
If this works.. the problem is probably the starter button.
If not...double check ALL the connections to the battery/solenoid/starter... you have probably left a wire off somewhere..( we have all done it!!)..make sure the right wires are in the right place...
Feb 26, 2017 | Honda 2005 FourTrax Rincon GPScape
I need to buy a new CDI unit for my 2012 Honda Rincon TRX680F. Who can help me??
Hi, Petro Honda no longer makes that part it has been upgraded to part number 38770-HN8-B41 which is very pricey for more information about your question and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
http://www.partsfish.com/oemparts/p/honda/38770-hn8-b41/pgm-fi-unit
Honda 38770 HN8 B41 PGM FI UNIT
Honda OEM ECM PCM CDI Module TRX680FA Rincon 2006 2016 38770 HN8 B41 SAVE
Rincon 680 service manual repair 2006 2016 TRX680 Download Manuals...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 07, 2016 | Honda Motorcycles
2012 Rincon turns over won't fire
Hi, Kim and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Faulty fuel pump fuse or relay.
11. Security alarm needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.hondaforeman.com/128-foreman-450/82769-starter-problem-i-think.html
http://www.hondaforeman.com/146-honda-rancher-350-400-420/81917-2007-420-cranks-but-won-t-fire.html
Rincon 680 service manual repair 2006 2016 TRX680 Download Manuals... $ 5
http://owners.honda.com/assets/OWNERLINK/model/own_man/powersports/2007/2007_TRX680FA_FGA.pdf Free
Mar 25, 2016 | Honda 2012 FourTrax Rincon Base
THIS PROBLEM IS INTERMINTANT . A 2005 HONDA RINCON POWER TO IGNITION SWITCH GOES DEAD OCASSINALLY. ONE MECHANIC SAID IT WAS THE BATTERY. IS THIS POSSIBLE?
First check the battery connections are good,then make sure the battery is fully charged,check the fuse on the ignition system is good. Sometimes fuses partially blow and are affected by the temperature making it work intermittently.
Mar 02, 2015 | Honda 2005 FourTrax Rincon GPScape
2005 Honda Rincon 650, When I try and turn it over it resists to start?
If its trying to start but barely turns over the starter is bad, since the battery is new and I assume fully charged, and all connections are clean and solid.
Aug 20, 2014 | Motorcycles
Troubleshooting 4x4 honda rincon 2003 650
If it is vacuum actuated, check the hoses for leaks. Check out the wiring if it's electronic.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_843b43f7ebebd3f5
Mar 26, 2014 | 2003-2005 Honda Trx650fa Rincon Cold...
Honda Pilot 2003 won't start. batter is good. seems to be an electrical issue because starter won't turn at all and there are strange clicking noises when key is turned
I would be re-checking the battery. Make sure that when you have it tested they do a "load test". Sometimes a battery can seem good, but be bad when there is a large load placed on it. This test will reveal if that is the case. It could also be a starter problem, and it is possible (but unlikely) that it is a wiring problem.
Sep 19, 2011 | 2003 Honda Pilot
03 escalade won't start or turn over
Do you have power?
battery might be drained cause your alternator is not charging anymore, 2003, seems about time for a new alternator, those vehicles consume lots of power cause pretty much everything is electric, lots of motors and servos, so they depend a lot on a good power source from the battery. If alternator doesnt charge it, no power...
have power system checked.
Good luck.
Aug 20, 2011 | 2003 Cadillac Escalade
I have a 2003 Honda Silverwing. Dead battery (it seemed) this spring and I charged it and ran the bike for two weeks. Thursday, I went to start it and it showed completely dead. I went and purchased a new...
you will need to attach an Ohm meter to the battery when it is fully charged then pull around at all wiring on the cycle to see if the meters reading changes to OL. When that happens that area of wires is your short
Apr 23, 2011 | Honda Silverwing 600 ABS Motorcycles
Wanting to know if cylinder head off from a 680
no buddy because the barrel has gotten bigger and the head also has gotten bigger maybe would if you had the barrel aswell
Sep 29, 2009 | 2003 Honda XR 650 R
HMF Exhaust Honda Rincon 650 03-05 Logo
62 people viewed this question
Top HMF Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a HMF Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
