Question about Thermador Kitchen Ranges
What to do when my thermador oven preheat light blinks 4 times then 3 times heating
2 Suggested Answers
SOURCE: Thermador Pro Harmony Range--> Blue Lights Blinking
thermador rang, blue light blinking. Oven is not working,
Posted on Feb 05, 2010
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
Thermador P304CS error code 4 preheat blinks then 3 heat blinks
I wanted to post this up in case someone has trouble finding an answer and what worked for me. I found somewhere else that the 43 code (4 preheat;3heat) blinks was specific to the cooling fan or the temp sensor. I had started to remove the temp sensor off the back wall of the oven but was unsure where the wire ran to. There is a specific Ohm value it should have around 1080 I think (not 100% postive).
What I found during that search is what solved the oven problem for me. On the top of the range, if you pull off the grill grates and remove the center stainless cover you can access under the burners. You can do this without removing any wires or hardware. In the back of this area is a small cover held in by 4 screws. Remove that. Underneath it is the cooling fan switch. It is a mechanical switch that when the fan kicks on it pushes a metal sail that then causes a connection in the switch letting it know the fan is operating. This switch had a little bit of corrosion on one terminal but it is also prone to getting dirty. Clean it off and try to restart the oven. The sail should move forward and the switch makes connection. For me once it was cleaned and any corrosion cleaned off, my oven worked just fine. This is a pretty easy check with the 43 code since it does not involve a lot of invasive work. Hope this helps someone.
Mar 07, 2010 | Thermador Kitchen Ranges
Oct 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
PRD486EDG doesn t heat up Oven light blinks once
PRD486EDG Oven doesn't heat up. Oven light blinks twice, then the heat light blinks twice. Tried reseting the power
Mar 18, 2009 | Thermador Pro Grand PRD486EDG (Dual Fuel)...
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Blinking oven and heating Lights
for no reason the cleaning light went on, even though the oven was not on. The oven light and heating light were alternating each blinking 5 times. The door locked up, too. It seemed to think it was in a cleaning cycle. Any way, problem solved by throwing off the main breaker and all is working fine since... except now, for no reason the oven fan, not the exhaust fan, stays on all the time!
Feb 12, 2007 | Thermador PG486GEBS Stainless Steel...
Kitchen Ranges Logo
63 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
