Question about Nintendo Multi-out Audio Visual A/v Cord Cable Tv Connection
My n64 av cable isn't working.How do I fix it
Every time I plug it in no picture or sound comes up
Linkums
  • 30 Answers
SOURCE: N64 works but the Picture has loads of static
It sounds like it's most likely a problem with the AV cord you're using to connect to the TV or the ports on the TV where you plug it in. If you can, borrow a friend's AV cable and see if it works, if not then it's either a technical problem elsewhere or it is not hooked up correctly... Also make sure the TV is set to the correct input (Video 1, Video 2, channel 3, etc.)
Posted on Oct 22, 2007
Nobarai
  • 57 Answers
SOURCE: N64
The clean the connectors on the cartridges and game deck before plugging it in and turning on the deck.
If this doesn't work, the cable is broken and will need to be replaced.
Hope this helps!
Posted on Nov 24, 2008
  • 52 Answers
SOURCE: Is my n64 broken?
You might have a dead N64 bro. Alot of quality games on that system too.
You can usually find them on Ebay for fairly cheap
Posted on Feb 11, 2009
  • 18 Answers
SOURCE: N64 light comes on, but nothing comes on screen
Make sure that the game you are trying to play is free of dust and other obstructions.  I know that the label on the back of the game says that you should never blow on the edge connector, but it doesn't harm the game. (Trust me I've been cleaning the connectors for years now, and it hasn't been damaged.  After you throughly rid the game of dust, do the same with the edge connector on the N64.  Simply hold the opening open and blow the dust out.  This should work.   Please give feedback!! Hope this helps!!
Posted on Apr 16, 2009
  • 894 Answers
SOURCE: My N64 will turn on,
Well it might be a power supp;y issue or and a laser assembly failure then.
Posted on Jun 25, 2011
2 n64's power on but no sound or video
the contacts that are in the n64 are probably burnt out in the back or the system is not reading the starter/expansion pak cuz mine did the same thing when the starter/expansion pak slot stopped reading.
Aug 22, 2012 | Nintendo 64 Console
I bought a new AV cable for my nintendo 64 off ebay and when i plugged it in the brightness of my games were really bright
Well it could be because HDTV was not made the time N64 cameout so you would have to use a blue plug for it to work instead of the traditional av cables.
Jan 19, 2012 | Nintendo 64 Console
Im triyng to hookup my n64 and its not playing on the screen? what do i do
Switch through the inputs to find the one that matches where you plugged in the AV cables of the N64. Try resetting your N64 or put in a different game. If that doesn't work, try to plug in the N64 into a different television.
Mar 01, 2011 | Mitsubishi WS-65869 65" Rear Projection...
I've plugged in the red, white, and yellow cables to my TV, and I'm getting sound but no picture. I've plugged in the cables the same way I successfully do for my Wii, but still get no picture. PLEASE...
There is probably a short in your av jacks somewhere, try going to a pawn shop or resale shop and getting some used av jacks off of another N64.
Nov 21, 2010 | Nintendo 64 Console
My Tv doesn't display the N64 game. No sounds come out also.
What you need to do is, first check the tv av input is working, use a dvd player or any other device with the red, white and yellow plugs.
If it works, the problem may be the nintendo AV cable, they are cheap and worth the few bucks to re live all those nostalgic game moments. If replaceing the AV cable doesnt work, check all the solder joints around the AV socket on the N64 main board. I hope this helps. Good luck.
Aug 07, 2010 | Nintendo 64 Console
How do i connect and use a Nintento 64 with a panasonic TX-26LXD60. I know it won't work with aerial connect as with my old tv. And HDMI cable is not correct size. I have a cable that connects to Nintento...
try the av cable with the 64 on another older tv... if the picture comes up, then you probably wont be able to use the n64 on your new tv... if the picture dosnt come up, then there is a problem with your cable...
Feb 18, 2010 | Nintendo 64 Console
No matter what tv i plug this console into, it does not work
my n64 part is not working the part u plug n the tv
Sep 01, 2009 | Nintendo 64 Console
N64 AV port loose, does not work
push in harder if does not work blow out socket alternatively, contact nintendo
Jul 14, 2009 | Nintendo 64 Console
Oct 17, 2007 | Nintendo 64 Console
Nintendo Multi-out Audio Visual A/v Cord Cable Tv Connection Logo
78 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
