Question about Nautilus E514 Elliptical Trainer
Computer screen on ev18 does not come on
Machine is plugged in but no power comes on
When i put my computer the screen doesnt come on and i dont hear the fan runing
check your cable coming from plug to pc, and check the power supply box of your pc, one out of them will be faulty because current is not coming to your computer thats y no activity or sound is coming
Sep 12, 2010 | E-Machines eMachines Desktop PC
Computer starts up but nothing comes up on the screen
Depending on the type of computer you have, when rebooting keep hitting the F1 key or F2 key or the F10 and when the options come up select the main hard drive (c:\ )and hit enter.should boot up to main drive. If it a Mac, take out battery and plug in power adaptor and hold start up key until machine starts up. once booted plug battery back in.
Sep 05, 2010 | Gigabyte GA-8PE800 PRO Motherboard
Hi, when i plug in the charger, there is power running throug the system, the green power light comes on when i press the power button, but the screen does not come on, nor do i hear the sound of the...
The battery could be bad causing the computer to not come on at all. Batteries last 1 or 2 years in normal use and less than that if not charged and used according to directions.
Aug 17, 2010 | Compaq Evo N800V PC Notebook
The start green light on our dell dimension 9100 is blinking amber. I can turn off the machine and back on but machine won't boot up. Any ideas? span.jajahWrapper { font-size:1em; color:#B11196;...
If you see the boot screen, then it is a problem with your operating system (windows)
If you do not see the boot screen, then it is the power supply or the motherboard isn't working.
If it turns green but you never see the screen come on, then it may be the video or the monitor.
If it does go directly to blinking amber, it is probabbly the power supply. It should only take a little while for a computer person to plug in another power supply and test it.
You can actually take a power supply out of someone elses computer and plug it in (don't even have to mount it in the computer)
Plug in the motherboard plug(s) and the hard drive only, then attempt to start.
If it does work, it is your power supply, if not then it is your motherboard.
Jan 24, 2010 | Dell Dimension 9100 PC Desktop
No screen picture
You should first try to find out if it is a screen problem. Turn the machine down, and plug a monitor to it. Turn monitor on, power up the computer and see if you get anything on the monitor. If you get something (like the boot screen) on the monitor then it is not your screen. You will be able to troubleshoot further by going into Bios Setting.
Hope it gives you a statring point.
Aug 28, 2009 | Toshiba Satellite A135-S4527 Notebook
Flat screen monitor functioning strangely
Sounds like there maybe bad caps on the power board in the LCD. Try a different monitor on your computer and if the known working monitor comes on with the computer and behaves properly then you know its a problem with your original monitor. If the known working monitor acts strange as well then you know its a problem with the video card. Let me know what happens.
Jun 11, 2009 | E-Machines eMachines Desktop PC
Monitor power light blinks blue but does not power on
if the screen was fryed the fuse would of blew which means there would be no lights at all.. the best thing you can do is plug your screen into another pc to see if anything happens.. if nothing happens then yeah your screen must of messed up somewhere.. but if your screen works on another computer then your graphics card config cant be right somewhere along the line
Jun 10, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Monitor shut off and will not come back on
Fmiliair proble, check not the plugs on the screen but the ones on the back of the PC, when the screws are not used the plug sometimes get a little loose and when the monitor gets no signal it will go blanc.
However, power lights on monitor should still be visible.
Jan 15, 2009 | Acer AL1706AB LCD Monitor
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Nautilus E514 Elliptical Trainer Logo
24 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
