Question about Yamaha RX-V630 Receiver
Yamaha rx-v360 lcd screen
Im getting power but nothing comes up on the LCD screen.
SOURCE: Won't stay powered on
There is a relay right next to the fuses on the inside dg1u it says on the top. I cleaned it and pressed down firmly on it and it seem to have fixed it. It fired up for the first time.. The relay might need to be replaced if this doesnt work for ya.
I found a solution at: http://www.diyforums.net/forums/domestic-electronics/11098-yamaha-rxv795-receiver-shuts-itself-down-after-some-time.html
Posted on Dec 29, 2007
SOURCE: Yamaha RX-V463 component hook ups
This receiver does not have video conversion capabilities. In the owners manual it mentions this. So HD in = HD out. Analog in = analog out on the video portion
Posted on Nov 06, 2008
quang123
  • 107 Answers
SOURCE: problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Posted on Dec 01, 2008
Benimur
  • 6966 Answers
SOURCE: Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 20, 2008
dunnbiker
  • 8546 Answers
SOURCE: Is the Yamaha RX-V596 capable of using HDMI in
Nope. Use S-Video or composite video In and digital audio in from the Cable Box, S- or composite-video out to the TV/Monitor.
OR (what I do) skip the receiver as a video middleman and take the HDMI video right to the TV; and run the Cable Box digital audio to the Receiver.
Posted on Feb 19, 2010
I cant get zone 2 to work on my yamaha rx v673. They are 2 outdoor speakers.. please help
I had a similar problem where I could not increase zone 2 volume - Page 100 in the manual notes that 'power amp assign' must be set to "7 Ch + 1 zone" before zone 2 max volume can be changed. Try that.
Jul 08, 2012 | Yamaha RX-V663 Receiver
I just put new batteries in the remote how do i get zone 2 & zone 3 to show on remote control? Yamaha RX=V1400
If you are referring to the Yamaha remote, slide the switch on the side of the remote to "Amp" then, using the "select" arrows up or down, toggle till you get to "Zone 2" or "zone 3" Once that's displayed on the LCD screen of the remote, press "system power" That should do it. If you still have a problem, post a reply and i will help you further
Jun 26, 2011 | Audio Players & Recorders
Light does not come out on the lcd of the rx-360
Pilot light burned out and has to be replaced. 14.5V 115mA lamp part number VA739600.
Nov 17, 2009 | Audio Players & Recorders
My yamaha rx-550u receiver won`t power up, no lcd display,nothing?
open it up and check the fuses and the power supply should be +or - 45 volts and the low voltage regulator +or -15 vdc
Sep 15, 2009 | Audio Players & Recorders
Blank screen on motorola v360v
your LCD was damage . So you can go to the mobile hardware point and checked out .
Mar 07, 2009 | Motorola Mobility V360 Cellular Phone
My yamaha receiver LCD screen dose lit when power up
Is it an RX series receiver?
I've repaired 2 of these recently with the same problem you have.
There's a very small 14 volt bulb that fits into the hood on the back of the LCD display.
It's about 0.15 inches in diameter and will need to be spliced into the existing two pin cable ( after you cut out the bad bulb)
Feb 14, 2009 | Yamaha Audio Players & Recorders
Dec 19, 2008 | Yamaha RX-V663 Receiver
Nov 02, 2008 | Yamaha RX-V463 Receiver
Yamaha AV Receiver RX V-995
You may have a problem in the primary stage in your Power supply !! Unhook everything that is attached to it .... make sure the power plug is in good shape and you have the right amout of ac at the plug and good grounding ... then then try turning it on again ....
Does it stay on ??
if not .. there is something wrong probably in the primary stage of the Power Supply ... could be a bridge or something like that
hope this helps
Feb 29, 2008 | Audio Players & Recorders
Yamaha RX-V630 Receiver Logo
35 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
