Question about Avanti Hot and Cold Water Cooler
Cold water not coming out - Avanti Hot and Cold Water Cooler
Cold water isn't coming on just hot water?
check the screen it the machine end of hose .make sure the hoses re on the right place
Mar 15, 2015 | Washing Machines
No cold water coming into machine
Follow the cold water line inside the washer where it connects to a 'Fill Valve' which is a valve/solenoid. Using an electrical test meter check the two wires at the solenoid for 110 volts when the machine is calling for cold water. If there is voltage but no cold water the valve is most likely bad. You may also want to pull the hose to make sure you have water running through the hose from the spigot. With the hose off at the valve look to see if there is a screen at the valve that might be clogged.
Dec 04, 2013 | Roper Washing Machines
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Apr 25, 2013 | Washing Machines
Only hot water is coming . cold water none
Ensure the hose's at the back are in the right places, Could be you or the fitters has put them in the wrong place.
Feb 20, 2012 | Kenmore Washing Machines
Setting is on cold/cold, but only burning hot water is coming out. When I switched it to warm/cold, it got a little cooler but still not cold. The hot/cold setting is also just warm water, so the hottest...
This seems to me to be that the hoses are connected backwards. It matters very much which hose is connected to which inlet. Make sure that the hoses are on Hot to "H" and Cold to "C" on the machine.
Aug 29, 2011 | Admiral AW22 Top Load Washer
Hot water comes out cold side for few seconds and gets cold, no hot from hot side, only cold
Make sure that the water pipes for the cold water coming in and the hot water going out are connected to the correct positions on the water heater. If the connections get reversed, the water that is supposed to be hot will be drawn from the bottom of the tank and will not be as hot as it should be. The cold water input goes to the bottom of the tank. The hot water out comes from the top of the tank.
Oct 09, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Cannot get cold water to come into the washer
Turn off the water and reverse the hot and cold water connections going into the faucet, then turn the water back on. If only cold water comes out of the unit when on hot temperature then you need to order a water valve solenoid which I suspect is the problem or wash only in cold water. They are replaced by removing the back washer panel a couple of bolts, one connector, and two hose clamps. Remember to restore the hot and cold water connections.
Jul 14, 2009 | Whirlpool Washing Machines
Cold water doesn't work in my washer
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
    if this helps please vote me a fix ya
Jul 18, 2008 | Washing Machines
Avanti Hot and Cold Water Cooler Logo
26 people viewed this question
Top Avanti Water Filters & Coolers Experts
John Tripp
John Tripp
john h
Are you an Avanti Water Filter and Cooler Expert? Answer questions, earn points and help others
