Question about Samsung WF337AA Front Load Washer
SAMSUNG WASHER SMELLS AND STAYS DAMP
EVEN BY LEAVING DOOR OPEN,INSIDE THE DRUM AND SEAL STAYS DAMP AND SMELLS. OUTSIDE OF DRUM IS COATED WITH YELLOW BROWN WAXY LOOKING GOO, CAN ONLY WIPE SMALL AREA.
    Problem Solver:
  • 12 Answers
I fixed the bad odor problem once and for all!
This problem is caused by mold and mildew growing in a large ventilation hose that runs from the top of the wash drum to a large vent hole in back of the machine.
To correct this problem you can buy a kit from http://washerfan.com/ or do the cheap fix like I did.
Step One: Find the vent grille on the upper left corner of the machine. Remove the machine top, only a couple small screws hold it on.
Step two: Remove the hose clamps that hold the hose to the drum and grille then snap out the plastic grille.
Step three: The grille is convex so I used a belt sander to make it flat then I took a computer case fan that was the same size as the grill and hot glued it to the plastic grille. I wired it to an old 12 Volt phone charger (12V 500 Ma) and made it blow air INTO the vent.
Step Four: Put everything back together and enjoy a stink free washer because the mold can no longer grow in that hose.
Note! You must bleach, clean and scrub that crud out of that large vent hose and it is some kind of gross! If you're allergic to mold please wear respiratory protection. My fan has been blowing air into the washer 24/7 for six months and I have seen those case fans run non stop for years. It it dies just snap the hot glue beads and put another fan on it. Total cost for the entire fix, about $10.00
Also note that you have to leave the door open a little bit for the air that blows in the back to blow out the front door.
Posted on May 08, 2014
SOURCE: mildew smell in front loader
Yup! I have the same issue with a WE206BNW (Canadian model). Did the same thing - dried the water off the door and leave the door open when not using it. Sort of helped, but then I ran an empty light load with bleach through it - no clothes, just water. Helped a lot.
Henkfish
Posted on Jun 08, 2009
SOURCE: when i opened my washer it smells like mildew.
With the washer empty, put in a cup or two of bleach and then run a complete cycle with HOT water and the HIGHEST water level setting. When the agitation first starts, wait a couple minutes, then turn off the machine and let it soak with the bleachy water for about 20 minutes - then turn it back on and let it finish the cycle. If it's REALLY a strong smell, add some Simple Green, or some other NON-AMMONIA detergent to the bleaching process. (Mixing ammonia and bleach together is a MAJOR no-no. It gives off nerve toxins. Very bad.) If you can't find Simple Green, then add some dishwasher detergent. Not dish soap, like Dawn or Joy, dishWASHER detergent like Cascade or Electrasol.
That should help.
If it doesn't help, then unplug the machine, turn off the water supply, disconnect the hoses, and pull the machine away from the wall. Check UNDER the machine for the problem... If the machine, or the hoses, or the drain have been leaking, the mildew smell may be coming from your floor or walls as they rot... If that's the case, you'll have to find and fix the leak, and then repair your floor and/or walls.
Also, check your dryer vent connection... When your dryer is running, do you get hot, damp air coming out from behind it? If so, the vent pipe connecton may be loose, in which case you probably have a build up of dryer lint behind and under both macines.. This can be a fire hazard (especially if you have a gas dryer) and if combined with a little water from the washer, can start to mildew and smell. Reconnecting the dryer vent correctly and cleaning under both machines may solve the issue.
Hope that helps!
Posted on Jul 10, 2009
woobie dog
  • 1273 Answers
SOURCE: front of washer shows something inside the plastic on outside
It may just be spilled soap/softener the escapes from the tray when you load the dispenser. Happens here regularly. We just wipe it down from time to time.
Hope this helped. --W/D--
Posted on Jul 26, 2009
  • 662 Answers
SOURCE: The smell that comes from this machine is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Posted on Jun 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: Samsung front loading washer has a 'musty'
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 28, 2010
Smell of mildew in washer
They make products to eliminate this mildew, check at the store.
Aug 30, 2017 | Washing Machines
Why and how to get rid of smell on clothes with a kenmore He2 front load washer
Hi. inside the door seal is a lip that will grow mold or some kind of soap scum that turns black. pull back the edge of the door seal and wipe out with spray bleach ( wear gloves ). Leave the door open a little when you are done using it and that will help to let it dry inside.
Good luck
Aug 24, 2014 | Kenmore HE2 Plus Front Load Washer
Why is there a damp smell when I open the door?
Front load washing machines have to be hermetically sealed so they don't leak. Of course opposite of their top-loader cousins. :) In your case, Try cleaning the drum and the door seal and also remove any and all soap residue that you can find. Then try running an empty load with vinegar and/or Borax. You can try bleach, too if that doesn't work. When it's all clean and smells 'normal' again, be sure and keep the door cracked open when you're done using it from now on. Being closed and sealed all the time is why mold and mildew have grown, causing it to smell bad. I hope this helps! :) -Jason
May 02, 2014 | Samsung WF1124XAC 1400 Spin 12kg Load Eco...
My Samsung front load washer, which is about 1 1/2 old, smells like mildew. I've read that people put bleach in the drum and run it on a maintanence cycle and I'm wondering how I do that. ...
I had this problem too---same washer. The rubber door seal often harbours moisture and it's hard to clean just by running a cycle. You'll have to scrub away the mildew by hand.
Get a pair of gloves, a soft sponge, and a bucket of hot water with soap and bleach. Open the door. Press the sponge into the folds of rubber where the moisture is trapped. Work your way around the circumference of the seal. Repeat until the black goo is gone. Finally run a rinse cycle with some bleach.
Avoid this in the future by leaving the door ajar when not in use. Tuck an old towel into the seal to wick away the water.
Let us know if the smell is still there.
May 20, 2011 | Samsung WF337AA Front Load Washer
Smell of mildew on our towel and sheets
This is probably happening because the clothing is being left damp in the washer. When it is warm during the summertime mildew will grow very quickly in the towels. On front load washers you need to leave the door open when not in use to keep mildew from growing. You should wipe out behind the inner seal any moisture when you are done doing laundry. This is an issue for most front loaders. Some front loaders have a clean washer cycle that uses bleach to sanitize the drum. Other washers like the Samsung have a block of silver and release silver ions in the wash to sanitze the clothes.
Sep 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
LG washing machine has AWFUL mildew smell
have you tryed a boil wash with nothing in the washer to soften and expel any caked powder in the drum?i know this does help
May 27, 2009 | LG WM-2277HW Front Load Washer
Maytag neptune smoking
it could be the seal on the drum or it could be the belt getting too warm
Jan 12, 2009 | Maytag Neptune Washer
Smell in Front Loading GE Washer GCVH6260F
more likely due to using liquid detergent - change to powder
Dec 01, 2008 | GE Energy Star WCVH6260F Front Load Washer
Inside of Washer Smells
often in washing machines there is a drain trap which needs cleaning out from time to time, (usually accessible from the front behind a removable facia) The manual should tell you how to clean this. you need to drain the water first (as there is often a little water still in the system). if you look on the program dial there is often an item that has an arrow pointing down, this should be the drain program, after this is done you can remove the draining cover and clean the workings inside, hopefullt this will solve your problem :)
Sep 27, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Samsung WF337AA Front Load Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
