Question about Keurig B31
Keurig does not punch hole in bottom of cup - Keurig B31
cmccune04
  • 213 Answers
SOURCE: Missing Keurig part
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Posted on Apr 13, 2010
tgmusicgirl
  • 91 Answers
SOURCE: Coffee won't pass through pod
the K-cup is punctured at the top and at the bottom.
you can take a corkscrew, and puncture a number of holes in the bottom of the K-Cup... verify there is a hole at the top... just before you start to brew... press down on the black arm over the cup... but not too hard...Lets see what happens... if it all looks good... no problems... then we need to either adjust the arm... or shim the k-Cup up a little bit...
you may also check the rubber Seal around the top pin that punctures the K-cup...
sounds like you lost your rubber seal around the top of the K-cup...
you can re-phrase after looking and testing....
Posted on May 06, 2010
cmccune04
  • 213 Answers
SOURCE: I need to find replace for internal chamber on Keurig
Go to http://www.Igotsweetdeals.com for all keurig replacement parts!
Posted on May 20, 2010
cmccune04
  • 213 Answers
SOURCE: Keurig replacement part
http://iwantsweetdeals.com/Top-Needle-and-Seal-Replacement-Part-Used-for-B40-B50-B60-B66-B70-B77-Brewers-P1227669.aspx
This is the whole assembly I hope this helps you!
Posted on May 26, 2010
heatman101
  • 43501 Answers
SOURCE: Keurig B70 top needle does
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Mar 21, 2011
Coffee grounds everywhere
The coffee can't get out.
There is a hollow metal pin that punches a hole in the bottom of the K cup to let the coffee out. Either it is missing or clogged.
Feb 17, 2015 | Keurig K350 2.0 Brewer
Water does not go through the k cup. when the cup is placed in the coffee maker and the lid is dropped down, the needles punch through the cup at the top and the bottom. the water spills over the top of...
Yup... the bottom needle is plugged...Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
heatman101
Sep 24, 2011 | Keurig B60 Coffee Maker
When my machine makes a cup of coffee it continues to drip water after the brew process - when you remove the K-Cup it dumps about an ounce of water.
There's a needle that punches a hole on the bottom of the K-cup. That needle is clogged. Poke it with a paper clip or a thinner wire to unclog it.
Aug 23, 2011 | Keurig Special Edition B60 Coffee Maker
The coffee grounds are dry after the cup is brewed. It does not taste like fresh brewed coffee.
There's a needle that punches a hole on the bottom of the K-cup. That needle is clogged. Poke it with a paper clip or a thin wire to unclog it.
Aug 23, 2011 | Keurig 5048 My K-Cup Reuseable Coffee...
My keurig won't punch a hole in the bottom of the kcup amd the water comes out squirting everywhere not in a stream
I had the same problem after 3 day's use. I discovered the metal punch was flattened. I used a pliers to bend it gently back up and it worked for a while. It quit again so I'm returning it. Meanwhile, I punch a hole on the bottom of the k-cup and line it up at the top when I insert it. It works that way.
May 02, 2011 | Microwave Ovens
I broke the peice that puts water through the coffee basket on a Keurig Elite B40 Coffee Maker where can I buy parts for this?
If you are talking about the K-cup holder that punches the bottom of the k-cups, they usually are not for sale, and you can only find them on ersale sites like Ebay.etc...
you could also go buy a "Keurig My K-Cup Reusable Coffee Filter"
and just use the main grey plastic filter holder... but you will have to puncture the bottom of the k-cups yourself before dropping them into the holder...
You wont need the filter basket or the lid if your using k-cups... just the filter holder...
dont forget to punch a hole in the k-cup first...
May 14, 2010 | Keurig Elite B40 Coffee Maker
B60 is not operating properly
I had the same problem and it turned out to be the pressure safety kicking in. The bottom hole didn't punch through on the K-cup. Check to make sure that is not the problem.
Nov 13, 2007 | Keurig B60 Coffee Maker
Keurig B31 Logo
48 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
