Question about D-Link AirPlus DI-524 Wireless Router
Need a wifi repeater - D-Link AirPlus DI-524 Wireless Router
    Champion:
    New Friend:
  • 219 Answers
If you have a spare router you can set that up to expand your wifi coverage.
Here is a magazine article how to do it: How to set up spare router to expand your Wi Fi network coverage
Posted on Aug 14, 2014
How do I CONFIGURE WI FI REPEATER
You'll need to configure your wifi adapter to the same network range as the repeater.
192.168.10.2 will work.
Jan 20, 2015 | Generic Wireless-N Wifi Repeater IEEE...
How to connect two wifi routers using modem....In home on one network???
while two WiFi connections can work, if youdo it that way you will need to disconnect from one and reconnect to other everytime you move from one extreme to the other. also you only extend your range by the distance from one to the other.
what you need (for a weak signal) is a repeater. it is a box designed to listen on one WiFi channel and repeat it on another. bin turn it also listens on the repeated channel for communication from your remote device and repeats it onto the original channel so it is as if the new channel is the original channel... place this repeater at half strength distance (power source will be needed but wires to base computer not needed) and you have extended your range by about half the distance...
to go further out just add another repeater (or more)
I googled "WiFi repeater" and was presented with a wide range of options (see photo for partial screenie)... generally the more expensive the further or wider the range... without even looking further i would suspect that the more expensive ones likely could even cover more range than two of that modem you showed combined
a few shown might be the kind with two units that you plug one near base computer and plug other farthest away from base... they not only use house wiring to power the units but also use the electric wire as an antenna for comunicating as if there were an ethernet connection between them.
fd91a783-bc64-463b-8de7-62ed56adbb31.pngMy
Jul 02, 2014 | Computers & Internet
Netgear extender not connecting
There's quite a bit to know about using WIFI network extenders / repeaters. Have a look here;
Simple Wireless WIFI range extender expander repeater
Apr 07, 2014 | NetGear Computers & Internet
My wifi (comcast/xfinity) doesn't reach the entire house
Make sure it is high enough and not blocked by a lot of stuff..
You may need a repeater
I have included a link.. this is not an endorsement any brand will do you do not need to spend a lot of money
http://ampedwireless.com/products/rec10.html
another brand.. from amazon
http://www.amazon.com/Edimax-EW-7438RPn-Wireless-Universal-Extender/dp/B00794RDVY/ref=sr_1_1?ie=UTF8&qid=1381649209&sr=8-1&keywords=wifi+repeater
Oct 10, 2013 | Computers & Internet
My repeater does not find the wifi network
It is possible that the repeater isn't in the range of the wifi. Watch out for the range of wifi router and then place the repeater in that range.
Jul 30, 2013 | Uspeed WIFI Repeater Access Point...
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
Dwl-2100ap set up propblem
There's quite a bit to know about extending / repeating WIFI signals.
Read about extending a WIFI signal with a Sitecom WL-130 repeater here.
Sep 05, 2008 | D-Link AirPlus G Wireless Range Extender...
D-Link AirPlus DI-524 Wireless Router Logo
98 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
