Mute icon stays on - Televison & Video
No mute
It looks as though there is no mute function.
Feb 16, 2014 | Jawbone ICON Bluetooth Headset
The mute wont go off
Check two things: first does the set have sound with just a DVD etc connected to one of the rear audio/video inputs? Second is check in menu that speakers are not turned OFF.
Oct 31, 2012 | Vizio Televison & Video
The mute button stays red. it will mute and unmute the icon on the screen but no sound from internal speakers ,only headphones will work.
You may need to try to re-enable the sound driver. Go into the start menu, then to control panel. If you're in Vista or Windows 7, click on Hardware and Sound. Then go to the Device Manager and find Sound, video, and game controllers. Expanding on the tab, you'll see the audio device. Right click on that, then select "disable". Once disabled, you right click on the same audio device and select "enable". Hope this helps!
FlamePants
Jun 01, 2011 | Computers & Internet
Where do i ftnd mute on my acer computer
Different laptops have different mute keys, one that Acer uses is fn+F8 (the blue function key(bottom left) and the F8 together). Windows also has a mute, left click the speaker icon (bottom right of screen) and when the volume bar appears theres a speaker icon at the bottom of the slider bar click that and it should mute the sound, click again and it should unmute.
Good Luck.
May 29, 2011 | Computers & Internet
The volume on my HP Pavilion Entertainment PC is stuck on muted. How to I turn mute off? I've tried tapping the touch pad button...
use your mouse go to the speaker icon and uncheck mute if that doesnt solve it that means there is softwware corruption or there is a piece of hardware like your touchpad causing it to stay on mute
Dec 12, 2010 | Computers & Internet
How to undo mute
There is a mini loudspeaker icon in the bottom right corner of the screen (system tray)
double click the icon - a box with all the components of the sound system will pop-up (Master Volume)
Untick any of the mini boxes along the lower part of the box that have a tick in them (click on the tick will 'untick' it - click on empty box, 'ticks' it)
That is the easiest way. BUT if you can't find the icon... Go to Start - Control Panel - Sounds & Audio Devices
Double click that Icon and in the window that opens... You will see two mini boxes Mute and Place volume icon in System tray Untick Mute and Tick Put icon....
Simples...
Brian
Nov 25, 2010 | Computers & Internet
The audio on my hp laptop only works when the headphones are plugged in, and the mute button stays orange and wont change to blue, but when i press the mute button the icon in the bottom right hand corner...
why not load the HP drivers of sound first.
that would proved its software or hardware so very easy
no>?
ever heard of HP>?>
NO OS stated, so how can anyone help lacking that KEY FACT.
windows what>?
you left out the dash, lacking the dash , HP cant find it.
G72-259WM
then go here. and use the right model and bingo.
support, all in 5 seconds work, posted here 1000s of times.
https://support.hp.com/us-en/product/HP-G72-200-Notebook-PC-series/4150030/model/4221434
then click software
then pick windows
then what what windows (today is how to fish day)
i guess and pick w7-32
and see what, the top of the list is driver -audio
load that driver, now.
if that fails, the hardware is bad, get it fixed.
Dec 26, 2017 | HEWLETT-PACKARD HP G72259WM Notebook
Something happened to the volume on my pc.....if I hi the mute button on my keyboard....how do I unmute? I've pressed the volumne button......I've done everything tech sayes to do re volume, sound ...
Click on the desktop tray icon sound button, and uncheck the mute button. If the icon is not visible just see by pressing the left arrow button if icon is present and remove the tick mark on the mute.
Sep 05, 2010 | HP Computers & Internet
I cannot get my sound to go up on my desk top computer. it stays on mute, when i press the icon it wont come up.
MAKE SURE THE DRIVER IS INSTALLED GO TO ( RIGHT CLICK COMPUTER, PROPERTIES, DEVICE MANGERM AND MAKE SURE NO YELLOW SHIELD SIGNS ON DEVICE
Mar 26, 2010 | HP Pavilion dv6000z Notebook
The mute Hot key on my HP Pavillion is stuck on red. I can't get any volume no matter what I try. When I touch the mute hot key it shows that the icon has been muted and then when I touch it again it takes...
if your comfortable pull the key off... re seat it then try it again... or disable hp media keys and reboot. also you can try going into the control panel sound option and remove the hp media controls and then re install them after
Mar 26, 2009 | HP Pavilion dv9000z Notebook
Televison & Video Logo
10 people viewed this question
Top Televison & Video Experts
