Question about Brookstone Wireless Weather Forecaster
Opening the case to repair - Brookstone Wireless Weather Forecaster
Removing the case to the Gateway (AK) MFATXPNT MDP E4100
What is the problem, opening the case should be fairly straight forward
Are you going to upgrade or repair
May 29, 2015 | Gateway Computers & Internet
How to open a nilfisk multi 20/30 casing to access motor
these machines are made to give the average person problems in repairing them to many screws and lock points,spring etc.your best bet is to take it to a vac repair shop for servicing,and save yourself the headaches!
Nov 06, 2014 | Vacuums
How to open case?
under the decals on ether side are four screws remove these and
separate the sides under these you will find white wedges that hold the case halfs together pull out these wedges and open the case. repair unit and Reverse the prosess to reassemble the unit. If you know how to work on electronics you may need to replace the electrolitic capacitors while the case is open. Kill 2 birds with one stone.
Oct 27, 2012 | Namco Arcade Classics Plug and Play TV...
Samsung Syncmaster 740NW vertical blue stripe
I've never opened one of these units, but I think you're right...a broken, cracked, or "cold solder joint"...had that problem on boards a lot of times. What has been assembled, should have a way of disassembling, unless the plastic was molded or glued after assembly, which is almost never the case, to my knowledge. Sometimes screws are hidden under labels, paper or metal plates, anywhere, really. If you can drop by a computer repair shop, you might be able to pick their brains about where the screws are, just depends on the person working there. Only other choice is to get the repair manual, but they're expensive and hard to locate, sometimes. Anyway, keep working on it, I think you'll figure it out!
Mar 14, 2010 | Samsung 931BF 17" LCD Monitor
Garmin 660 na repair
Please do not try to repair this problem yourself. You risk damaging the case and/or LCD display. In many cases, the headphone jack connections must be reinforced with wire and the jack itself needs to be epoxied to the board.
Please see this link:
http://www.sharc.net/gps_audio_repair.htm
- Jim
Feb 25, 2010 | Garmin Nuvi 660 GPS Receiver
My Nokia N70's back camera is not working when i open the case at the back it tells me "unexpected error occured. Power off device." How do i repair it
Hello :
First you shouldn't open the case , because it's a software problem .
Just update the software of your device and problem will be solved if you didn't corrupt anything when you opened the case .
good luck
Feb 08, 2010 | Nokia N70 Cellular Phone
Laptop opening for repairing toshiba
look for any litttle rubber feet. there is uasualy a combination of case clips where the case clips to itself and hidden skrews but pull the battery first and the power cord.
Dec 30, 2008 | Computers & Internet
Opening the case to repair broken power connector
FIRST FAIR WARNING: This take apart is best left to the repair tech's at an authorized repair facility. There are 6 snaps, two on the top, two on the bottom and one on eash side. I used a thin blunt tip letter opener and started at the top. This didn't leave any marks on the case that would tip off the repair tech's that you goobered it up inside which you will do if you proceed! Release the two at the top first, then the two on the bottom. Now release the one on the side where the power button is located. Open the case on the power button side only about 1/4 inch and slide the bottom off the top being careful not to separate the power cord and headphone connector plugs from the board that they a fastened to inside the case. SECOND FAIR WARNING: It is very easy to pull the connector plugs from the board and this will really convince the repair tech's that you ruined your $350 GPS. Good luck and don't say I didn't warn you!!!!!!
May 13, 2008 | Magellan Maestro 4040 GPS Receiver
Brookstone Wireless Weather Forecaster Logo
27 people viewed this question
Top Brookstone Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Brookstone Measuring Tool and Sensor Expert? Answer questions, earn points and help others
