Question about Samsung WF328AAW Front Load Washer
My Samsung wf328aaw/xaa front load washer won't power on
  • 1531 Answers
SOURCE: How to replace the door diaphragm on a Samsung
remove the lid.then you need to take off the control panel move it out of the way.there will be a spring that holds the boot in place on the front where the door closes remove this spring the rmove the boot from the front panel then remove the front panel.there will be another spring that holds the boot to the drum.i have found it easy to remove the counter balance weights to remove and reinstall the new boot. i hope this helps sounds like alot but not real bad
Posted on Sep 19, 2009
pride applia
  • 232 Answers
SOURCE: I keep getting a nf error message. what is this
water fill valve screens may be plugged filling too slow or valve may be bad or is one of the hoses turned off
Posted on Dec 31, 2009
SOURCE: My Samsung WF218ANW/XAA front load washer will not
lefever352, I am currently trying to solve this same issue on the identical model. I removed , cleaned, and re-assembled all the water tubes and the entire pump assembly. The pump works but for some reason it is not priming into the drain tube. The pump assembly appears to have a diaphram over the outlet opening and it it looks like this might be the problem. I am still hunting the solution, BUT so far the above actions have to resolve our issue. I hope perhaps Fixya can help.
Posted on Jan 22, 2011
SOURCE: How do I replace the oring gasket on a front
I can tell you how to fix one on the WF218ANW/XAA washer. Your model may be the same. You need to take the top panel off the washer by taking out two screws on back panel. You need to remove the control panel and place it on the top of the unit (it is attached with electrical cord). You need to talk out the detergent tray (press the clip in the middle). You then take off the front panel. it is not necessary to take off the door; however, to remove the panel you will need to remove the door latch mechanism on the inside of the door. To remove front panel, there are also two screws on the bottom of the unit. Once you have the front panel off, remove the old gasket by loosening the two springs rings. Pay attention to how the gasket is installed before removing. Replace gasket by installing inner portion first and replacing spring ring and tightening. Put all the parts back on the washer and install the outer portion of the gasket (with the spring ring). Samsung charges $130 to do this in my area and it's a pain in the neck.
Posted on Feb 12, 2011
SOURCE: I purchased a WF328AAW/XAA washer
I am having this same issue. Did you ever find a solution?
Posted on Mar 22, 2011
I have a Samsung front load washing machine wf328aaw/xaa. the washer stops when it gets to the drain function. The drain pump motor is not getting the 120 to run the motor. I removed and tested the
There is a water level sensor that could inhibit the operation of the pump if it is indicating that the water level is low. There is also a small relay in the control panel (on the control circuit card), which may have dirty contacts. That is the contacts are not closing properly. Unfortunately, this relay is not readily accessible to consumers and even quite difficult to service for the professionals. I posted a description of the repair or cleaning of the contacts on the question placed by another user "My Drain Pump Doesn't Work"
Oct 19, 2014 | Samsung WF328AAW Front Load Washer
I have a Samsung front load washing machine wf328aaw/xaa. the drain pump motor is not getting the 120 to run the motor. I tested the resistance on the motor and it tested ok as 13.8. when I put the w
Have you resistance tested the cable from the pub to the pump connections ? The sensor problem I had which was linked to failure to drain was connected to a piece of tube some sort of pressure sensor .. The tube had a split so it was not detecting the pressure (of I assume height of water left in the machine) split was at the top .. Bit of trimming of the pipe fixed the problem
Where is the debris filter in a samsung washer WF328AAW/XAA
you take the plug out
take the back off
it should be between the tub and the pump ((take the hose of and clean it))
Feb 02, 2014 | Samsung WF328AAW Front Load Washer
Wf328aaw hums but won't work
Could you please describe the problem you are having a little better?
Nov 17, 2012 | Samsung WF328AAW Front Load Washer
WF328aaw Samsung Washer, Will not power up. No lights no sounds, complete no power. Check the door if it was closed, check the breaker outside home, did the tech support in the accompanying manual. I did...
I have same problem. The way I get around it is I change the cord to another wall socket. Apparently this is a thing with Samsung washers of this model type. There is a way to dyi fix it, but it would involve buying the part and taking the top off and risking something else to fail
Jan 27, 2018 | Samsung WF328AAW Front Load Washer
I have an SR error code on my front load Samsung, even when it's turned off. What does this mean? Jackie
SR indicates there has been a power interuption. If not from a quick power outage, I suggest having a qualified Service Technician che for a loose connection.
Nov 18, 2010 | Samsung WF328AAW Front Load Washer
How do you install a pump motor on a samsung washer model # WF306LAW/XAA
remove back panel and you should see the pump .remove the clamps on the hoses and there should be 3 bolts securing pump to base, remove with socket, 1/2
Aug 26, 2010 | Samsung WF328AAW Front Load Washer
Samsung WF328AAW Front Load Washer Logo
47 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
