Question about Dometic Refrigerators
My Dometic cooktop pooling gas in tray on one side.
One side will light. Affected side will not light except the pooled gas in the tray.
    Top Expert:
  • Dometic Master
  • 6,498 Answers
Replace burner or if possible switch burners see if same happens maybe cobweb in line
Posted on May 27, 2016
4 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Water Pooling and freezing on floor of freezer
most likely you have a frozen drain in the freezer section so that whne your refrig defrosts the water runs out into the freezer compartment instead of the drain pan underneath. the fix is to flush the drain with warm water to clear the obstruction. the drain can be reached either by removing the cover in the freezer area or by back flushing the line from beneath the refrig.
Posted on Dec 11, 2007
  • 1122 Answers
SOURCE: Kenmore elite side by side has water that pools in the freezer.
you need to clean out the freezer drain at the back of the freezer,use a hair dryer and a hanger or maybe a shop vac can **** it out-mike
Posted on Mar 16, 2009
  • 98 Answers
SOURCE: water pooling under crisper trays
The drain is stopped up. take the top apart. The drain is in the middle at the back. get a hair dyer to throw the ice and you will see the drain. Do not break the from duct throw the ice. the drain is behind it. Air the the best way to unstop it.
Ken
Posted on Sep 26, 2009
Pilot light will light but won't stay lit in the on position?
You probably need to change out the pilot generator. That is what tells the gas valve that the pilot is lit. They wear out after a few years.
It's not a tough DIY but you may have to pull the burner tray which involves opening the gas line. A pool tech should be able to change it out for about $130.
Sep 07, 2013 | Pentair 250k Minimax Ch Ng Mv Heater
Hayward H250 pool heater will not light
see if pressure switch full voltage both sides or hi limits
Apr 26, 2013 | Hayward Pool Products Hayward H250 250k...
Teledyne Laars Series 2 pool heater just clicks when the heater thermostat is turned on
check to see if voltage on both sides of pressure switch if so see if ignitor is lighting if ok check to see if voltage to gas valve should be 24 volts on each if no voltage check transformer also
Jul 10, 2012 | Teledyne Laars Laars Lx Nat Gas Pool...
Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater keeps failing and giving me a ROL and SPR code. The thing is a little over a year old and only been used 1x last winter (we live in Florida). Cannot...
ROL code means Rollout.
This heater used a one time use switch in the cabinet on the left hand side.
The switch will look like a ceramic oval disk about 1.5" in diameter. It will have two wires coming from it.
This switch is one time use because it mean your heater is getting a bad burn. This could be happening due to:
1. High wind situation (could be random)
2. Incorrect gas supply
3. Incorrect venting (if indoor)
4. Obstruction on top of the burner tray.
There was a recall on the refractory kit with some of these models, causing the fire walls to crack off and fall on top of the burner tray. Thus causing the flames to rise too high inside the cabinet and therefor trip the rollout switch. The timeline for the recall matches your heaters date.
E-mail me if you need more help.
ahudson43@yahoo.com
Dec 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Can the minimax natural gas be converted to propane like a laundry dryer ?
Check out this link: http://ths.gardenweb.com/forums/load/pools/msg0522222224880.html
Per this link, these are the parts that you'll need to replace:
Natural gas burner tray 472028
Propane burner tray 471931
Propane gas valve 471671
Remember to always be safe around electricity and gas lines. If you're not sure then hire a professional.
If this has helped, please give me the appropriate thumbs up! Thanks, and good luck!
Aug 15, 2010 | Pentair Pool & Spa
Back flare on Raypak pool heater
You will need to pull the burner tray out and clean and blow out the burners. Then you will need to pull the orfaces from the gas manifold and clean each one and blow out the gas line. Then with a mirror you will need to check the fire brick inside the burner box. Then you will need to replace anything that is damaged. Good luck.
May 15, 2010 | Raypak 130,000 BTU Propane Gas Pool...
How do you clean the orfices of spider webs?
you have to remove the burner assembly to properly clean the unit. remove the front panel there are 2 screws on the burner tray remove these and disconect the small pilot supply tube and slide the tray out to clean. use a wire brush lightly and an air compressor to cleat out the burners and the orfice.
Aug 01, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pilot lights but burner will not fire
what burner where on the oven or the cooktop, if its the oven it may need new gas valve w\ thermocoupler
Jul 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Refrigerators Logo
15 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
