Question about Samsung WF328AAW Front Load Washer
My Samsung wf328aaw/xaa won't stay on - Samsung WF328AAW Front Load Washer
3 Suggested Answers
SOURCE: I purchased a WF328AAW/XAA washer
I am having this same issue. Did you ever find a solution?
Posted on Mar 22, 2011
michaelscarf
SOURCE: wf328aaw hums but won't work
Richard I have the same problem with my washer,did you find the problem?
Posted on Feb 07, 2013
I have a Samsung front load washing machine wf328aaw/xaa. the washer stops when it gets to the drain function. The drain pump motor is not getting the 120 to run the motor. I removed and tested the
There is a water level sensor that could inhibit the operation of the pump if it is indicating that the water level is low. There is also a small relay in the control panel (on the control circuit card), which may have dirty contacts. That is the contacts are not closing properly. Unfortunately, this relay is not readily accessible to consumers and even quite difficult to service for the professionals. I posted a description of the repair or cleaning of the contacts on the question placed by another user "My Drain Pump Doesn't Work"
Oct 19, 2014 | Samsung WF328AAW Front Load Washer
I have a Samsung front load washing machine wf328aaw/xaa. the drain pump motor is not getting the 120 to run the motor. I tested the resistance on the motor and it tested ok as 13.8. when I put the w
Have you resistance tested the cable from the pub to the pump connections ? The sensor problem I had which was linked to failure to drain was connected to a piece of tube some sort of pressure sensor .. The tube had a split so it was not detecting the pressure (of I assume height of water left in the machine) split was at the top .. Bit of trimming of the pipe fixed the problem
Where is the debris filter in a samsung washer WF328AAW/XAA
you take the plug out
take the back off
it should be between the tub and the pump ((take the hose of and clean it))
Feb 02, 2014 | Samsung WF328AAW Front Load Washer
Wf328aaw hums but won't work
Could you please describe the problem you are having a little better?
Nov 17, 2012 | Samsung WF328AAW Front Load Washer
My model hlp 4674 wx/xaa sceen won"t do anything
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
How do you install a pump motor on a samsung washer model # WF306LAW/XAA
remove back panel and you should see the pump .remove the clamps on the hoses and there should be 3 bolts securing pump to base, remove with socket, 1/2
Aug 26, 2010 | Samsung WF328AAW Front Load Washer
Our flat samsung 40 inch just clinks won;t come on
REPLACE 3 -4 CAPACITORS IN THE POWER SUPPLY, THEY ARE SWOLLEN UP OR LEAKY
Dec 30, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung WF328AAW Front Load Washer Logo
15 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
