Question about GE JTP27 Electric Double Oven
F0 error I have reset oven several times. After two minutes F0 error and endless beeping.
catriver
  • 878 Answers
SOURCE: F0 error - My GE Over displays an F0 error & constantly beeps
Appu, the F0 error for this built in means there is a shorted or stuck off key. Sometimes this can be resolved by removing the keypad ribbon cable from the board and cleaning the ends with an eraser. If that doesn't work, you want to find out whether its the board or keypad by ohming the ribbon cable, 3 to 4, probes on the conductor side...should read 125 to 1750 ohms while pressing the off key. Catriver..post back.
Posted on Apr 30, 2007
  • 10 Answers
SOURCE: GE Profile Performance Double Oven
I had a similar problem,  try the fix belowhttp://www.fixya.com/howto/h155060-dreaded_f7_error it may work.
Posted on Aug 20, 2008
SOURCE: GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Posted on Jan 22, 2009
jumptrout51
  • 3361 Answers
SOURCE: f0 error code on ge profile oven
Could be a stuck keypad. Try pressing all pads at random several times each to clear it.
If that does not work the ERC(clock) must be replaced.
Posted on May 26, 2009
  • 111 Answers
SOURCE: GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Jun 20, 2009
Dacor model ersd30 how do i fix an F0 error code that also blinks F1 and beeps
Hi dan8260,
If you're encountering F0 error code, it is due to a stuck function key. You need to replace the touch pad to fix this error. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Feb 07, 2011 | Dacor Epicure EO127 Stainless Steel Dual...
F0 Error code
your model number please?
Jan 21, 2008 | Ovens
I am getting an F0 error code on my GE JTP15. It was working and then just shut-off. Then the error code appeared. I removed power for 30 minutes but the oven control did not reset.
F0
Stuck touch pad Usually means that either the touch pad or the oven control
(also called clock or ERC) is defective and needs to be replaced. If this fault
code cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Jan 30, 2011 | GE JTP15 Electric Single Oven
F0 error code on ge profile oven
May 26, 2009 | GE Profile JTP18 Electric Single Oven
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
F0 error code on GE Profile PT956 double electric oven
you can also put a piece of paper between the ribbon cable where it joins up before the connector. It has been reported that the cable will short in this area. Try that before spending more money since most of the F-codes appear to be cable related.
Dec 01, 2008 | GE Profile PT956 Electric Double Oven
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
Double Oven says "F0" and beeps continuously
The fault code "F0" is indicating a possible stuck or shorted key pad or oven control board failure.
Determine if the problem is with the key panel or the oven control board by:
1. Pushing Clear/Off pad.
2. Disconnecting the Ribbon Cable Connector from the control board and waiting at least 32 seconds to see if the Code recurs.
If the code recurs, problem is in the control. Replace control.
If the code does not recur the problem is the Key panel and it would need replaced.
This test is normally done by an experienced service technician to avoid any possibility of getting shocked. This has to be done with voltage applied to the wall oven. Extreme caution should be exercised while testing.
I recommend calling a service technician to diagnose and repair your oven.
Jun 13, 2008 | Kenmore 47732 / 47734 / 47739 Electric...
F0 error
This may be related to a problem that I have helped others solve. The solution is free and can be found at my website which is: http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf It has helped over 1000 folks with a similar problem. Hope it works for you too.
Aug 08, 2007 | Kenmore 47722 / 47724 / 47729 Electric...
Apr 29, 2007 | GE Profile JK915 Electric Single Oven
GE JTP27 Electric Double Oven Logo
18 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
