Question about KitchenAid Refrigerators
My kitchenaide ksrx25f freezer or refrigerator is not getting cold
  • 159 Answers
SOURCE: Refrigerator does not get cold
ou need to check to make sure the evaporator fan is working. If it is remove the freezer back to look at the evaporator to make sure it is not frozen over. If it is you have a defrost problem. when the coils on the evaporator get all frosted over air can not move over the coils for the fan to circulate the air through out the compartments so the fresh food section will get warmer while the freezer will be cold. you will need to defrost the evaporator to be able to check the treminator and the heater. to do that you will need to turn the timer thats is located in the fresh foo section usually in back of the thermostat. there may be a removable plug to expose the dial to turn it manually. use a flat blade screw drier to do that. it will only turn one way. as soon as you hear a click stop. the compressor and evaporator fan should stop running. now you can check to see if the heater will come on. if not you will need a volt meter to check the terninator heater and to make sure the defrost timer is all good. you should have 120v at the heater. if you do ohm out the heater to make sure it is ok. most times if it is a defrost problem check the terminator first thats the round disk with 2 wires on it. if it is not closed the heater will not come on.check it out and you should find if there is a problem with the defrost cycle. if you turn the timer untill you hear it click again and the fan and compressor should be running. when you remove the freezer cover and you find the coils are only frosted at the top or just a verry little, you may have a leak in the sealed system and that would be why there os por cooling. you would need to call for service if that is the case. hope this help you some
Posted on Aug 10, 2007
Master_Tech
  • 770 Answers
SOURCE: Kenmore cold spot refrigerator freezer
wow you have power to the unit what about the temp control ? is it turned up?? if so is it closed(calling for cooling?) that is the place to start you can jumper it after yo unplug it to see if you dont have a meter
Posted on Jan 24, 2008
  • 958 Answers
SOURCE: Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Posted on Feb 19, 2008
  • 28 Answers
SOURCE: New Kitchenaid refrigerator often makes sharp bang noise.
I have an old Amana bottom freezer that does that. It's because the defrost heaters are doing their job and the area around them as well as the coil is expanding rapidly. Try making certain that the cabinet is level and not on an unsteady footing. You might want to try turning the T stat in the freezer to a lower setting. Usually between 2 1/2 and 3 1/2 works best in all freezers. If none of this helps and the banging continues, get used to it or get another fridge. It seems to be a failing in bottom freezer models for some reason. It's harmless but annoying. I actually know someone who says she has the ghost of a frozen turkey stuck in her freezer that's trying to get out! LOL!
Posted on Jul 09, 2009
aasc
  • 1606 Answers
SOURCE: KitenAid KSRX25F -- HOT FRONT FRAME
The fan which cools the compressor is not working , OR , the coils under the front of fridge are very dirty .
Posted on Aug 01, 2009
The freezer is leaking water out the bottom model #ksrg2tfkst18 kitchenaid
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 20, 2011 | KitchenAid Refrigerators
Our 3 months old refrigrator will get so cols that freezes food products.
There are actually 2 cold controls on refrigerator-freezers. The main control is within the refrigerator cavity, the other is located in the freezer cavity. The one in the freezer is usually only a cold air deflector. It takes the cold air that is produced and divides it proportionally between the freezer and refrigerator sides. Set the control in the refrigerator to about mid-range. Set the control in the freezer to mid range. That is your starting point. If the freezer is not cold enough, adjust the freezer control. If the refrigerator s not cold enough, adjust the fridge control. After any adjustments, you MUST wait at least 24 hours for the temp to equalize before making any more adjustments. It may take a week to get it set right. This is true for all refrigerator-freezer combinations. Be patient.
Oct 09, 2010 | KitchenAid Refrigerators
Our KitchenAid Refrigerator Model KTRS22EM is not freezing or cold enough in refrigerator Indicators are all at maxium , cleaned coils and you can hear it go on but not getting cold.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 01, 2010 | KitchenAid KTRS22EM Top Freezer...
Kitchenaid KTRS21KDAL refrigerator not cold but freezer is
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Jul 16, 2010 | KitchenAid KTRS19KKSS Top Freezer...
Aug 01, 2009 | KitchenAid KSCS25IN Side by Side...
Refrigerator side not cold
if you have frost build up on rear wall of freezer section then your unit is not going through defrost. its either defrost heater, defrost thermostat (which are both located on evaporator) or defrost timer
Jun 24, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
Freezer too cold frosty, and refrigerator section too warm
Sounds like a defrost problem if the evaporator is frozen over. If it's just Ice blocking air transfer on a top freezer model, then it's a blocked defrost drain.
Sep 10, 2017 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
