Question about Electrolux 30" Built-In Double Electric Convection Wall Oven - Stainless-Steel
How to access convection/light circuit board in electrolux wall oven
Convection fan/light circuit board failed. How do I access the board?
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Posted on Dec 25, 2007
apart4u
  • 213 Answers
SOURCE: my electrolux eod33002 bottom oven does not heat
If youhave a ELECTROLUX electric Cooker or Fan Ovenwhich is not heating it could be one of the following problems.
1, If the fan motor in theback of the oven is going round and the temperature light is on (normallylittle red light), but there is no heat then you will probably need a new ovenelement, these are generally very easy to fit and readily available from our websitethese can be tested with a electric meter.
To gain access to the ELECTROLUX element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if you look closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is opencircuit i.e. broken inside the element casing, either way it will needreplacing. Some elements will are fixed from inside the oven and some are heldin place by nuts from the rear of the machine.
2, If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
3. If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
4, A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Posted on Mar 04, 2010
SOURCE: After light cleaning-Electrolux Ew30ES65 upper
I had the same issue with my EW30EW55GS. This is the second time! The dirst time, the technician replaced all the circuit boards (took a month to get the parts). I figured, I would try a light cleaning again. SAME THING! Again, I'm without an oven for no telling how long. The oven looks great, but don't be fooled - it's a piece of junk!
Posted on Jun 08, 2010
  • 174 Answers
SOURCE: I have an electrolux EOB 945 fan oven that is not
fan element round the fan has failed
Posted on Jul 23, 2010
  • 4 Answers
SOURCE: replacing frigidaire wall oven door light/fan switch
Ask the Frigidaire Agent to go talk to a technician and get the answer to your problem. Technicians are available to the Agents. 1 (800) 374-4432
Posted on Oct 20, 2010
I'm getting a f24 code on my lower wall oven...what to do?
Hi. Error code F24 indicates that the controller has failed to communicate with the lower convection fan and oven lights control board. If the error code persists, I would recommend connecting with an expert repair tech to assist further and the display board may need replacing.
Sep 26, 2014 | Electrolux ICON 30 in. Double Wall Oven
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
How do I fix Error F 11 on Electrolux wall oven E30EW75ESS2?
Hello Nancy Keller - Typically, error code F11 indicates a shorted keypad. Try resetting the wall oven by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 08, 2013 | Electrolux 30" Built-In Single Electric...
I cleaned my electrolux oven for 3 hours and now my oven will not heat up any help please?
From what you have described sounds like you need to have the oven reset. Unfortunately, if resetting it at the household circuit breaker does not prove to be successful, then you will need a professional technician to pull the unit out of the cabinet/wall and reset it from the back panel.
Jul 31, 2012 | Electrolux 30" Built-In Single Electric...
My new oven electrolux EUEE63CS WILL NOT TURN OFF. display lights turn off but oven still going
My oven seems to turn off but the fan keeps working! Takes about 1hr for the fan to turn off after l have turned oven off. Is this normal? Im quite concerned. Will be calling help line monday morning......
Jul 28, 2011 | Electrolux 30" Built-In Double Electric...
Elextrolux Oven stopped generating heat. Grill working ok. Sparks came out of Fan area followed by cloud of ash. What could be the possible cause and what part could be required ?
Hi.
It will be the oven element that has failed.
This is located at the rear of the oven compartment where the the fan is.
Remove the cover at the rear of the oven there you will see the oven element, a very easy job to replace.
Nov 10, 2010 | Electrolux 30" Built-In Single Electric...
After light cleaning-Electrolux Ew30ES65 upper oven won't heat now! The bottom oven works fine, the lights are all on, the convection fan works in the upper over but the heating elements don't heat now....
Apr 04, 2010 | Electrolux ICON Designer E30SO75ESS Oven
Kitchenaid double digital convection conversion oven keypad went out. Any ideas on the problem. Electric panel circuit breakers are okay. Sharon C.
I think these use the same controller board as the Jenn-air units, they have a weak capacitor (C3) on the control board (Timer/control Display). Remove the top panel and look for a discolored or leaking capacitor (usually black about 1/2" high 3/8" in accross). Replace the capacitor and the problem goes away, until next time you use the self clean cycle which seems to overheat the control board and ruin the capacitor.
Sep 23, 2009 | Electrolux 30" Built-In Double Electric...
Replacing frigidaire wall oven door light/fan switch
May 14, 2009 | Electrolux 30" Built-In Single Electric...
Electrolux 30" Built-In Double Electric Convection Wall Oven - Stainless-Steel Logo
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
