Question about Malibu ML88TL 88Watt Low Voltage Power Pack with Timer
How to reinstall the trim ring for Elco EL1488
There are two trim rings on the EL1488 unit: a larger outer ring attached to the flanges which press fit the unit into its mounting can; and an inner ring which holds the lamp and turn mechanism. How does one install the inner trim ring into the outer/larger trim ring.
How to replace 1950 Chevy headlight
These sealed beam headlights have a chrome ring around the outside edge...this ring must be removed by one screw located in the ring...you can just loosen it to remove...usually located at the bottom of the bulb...when this is removed, you will see 2 or 3 springs attached to the bulb...these also need to be removed and you can then slide the bulb out from behind the chrome trim...reinstall in reverse...hope this helps.
Nov 04, 2015 | Cars & Trucks
Why is the harmonic balance eating into the timing cover?
On most vehicles today, the crankshaft pulley acts as the harmonic balancer. It also has the grooved outer ring that the serpentine belt rides on. Between the central hub of the balancer and the outer ring is a strip of rubber that the outer ring is pressed onto. This rubber, over time, ages and shrinks. This allow the outer ring to walk inward (or outward) of the centerline of the pulley. This causes the serpentine belt to wear out prematurely and can cause the problem you describe. You need a new harmonic balancer. It comes complete with the rubber and outer ring already attached. Check your belt at the same time to see if it needs replaced as well.
Oct 22, 2015 | Cars & Trucks
I need the outer flange/blade clamp for my Skil model 77 type 15
This sounds like a worm drive. Try going to this web site to order your part.
http://www.ereplacementparts.com/skil-shd77-f012sd7700-worm-drive-skilsaw-parts-c-130_160_7479.html
This is the part for the blade clamp washer $5
Blade Clamp Washer
This is the flanged plain washer $4
Blade Clamp Washer
and retaining ring $4
Retaining Ring 2610341359 for Power Tool eReplacement Parts
Dec 03, 2014 | Skil Saws
How to Replace rubber seal on front load washer
The rubber seal on your washer and similar front loading washers is a relatively easy repair. The seal is held onto the front washer panel and the fixed inside washer drum with separate spring-loaded rings that are reusable. So, don't throw them away! You need to remove the front ring from the front panel before you can remove the front panel. With the ring removed the gasket should be pushed into the washer; noting any drain holes, so that you can reinstall the new gasket in the same orientation. Once the outer ring is removed and the front panel is out of the way, you will have access to the ring holding the gasket to the drum. After the inside ring is removed, the gasket should pull off the fixed washer drum. You are now ready to install the new replacement gasket.
The amount of disassembly of the front of the washer is your option if it interferes with the installation. The door is usually heavy and it is useful to remove it from the front panel. Usually, a couple screws holds it in place. Removal of the front panel may also involve removal of the top of the washer and moving the control panel out of the way so that you can access the screws holding the front panel onto the frame of the washer. The locking latch may have to be temporarily removed but can be left in place if you simply push the front panel out of the way to have access to the inside gasket ring. It is useful to take pictures of each stage of the disassembly process to make sure your reinstall everything as it was.
Installation of the gasket starts with reattaching it to the fixed washer drum flange and then replacing the spring-loaded ring to hold it in place. Make sure the gasket orientation matches the original position. After the gasket is attached to the drum, you can now reinstall the front panel. If you unscrewed the latch mechanism when you took off the panel, now is the time to reinstall it as it can be manually held in place behind the gasket. The door can usually remain off the front panel until installation of the gasket onto the front panel is complete. Now bring the gasket forward and reinstall it on the flange of the front panel; secure it in place with the spring-loaded ring. Your gasket is now reinstalled. Simply reinstall the door and your repair is complete.
Tools needed include a blade screwdriver to help pry the rings off the gasket seal and one or two specialty screwdrivers (usually Torx or Philips) to remove the front panel.
Aug 05, 2014 | Frigidaire Washing Machines
1993 electra glide front faring removal
1993/1994 Outer Fairing and Windshield for FLHTC, and FLHTC ULTRA
Removal
First remove the headlight assembly and the bolts, nut and the washers attaching the outer fairing piece to the windshield and inner fairing piece. THEN loosen the four bolts attaching the light bracket and the outer fairing piece to the fork brackets. Remove the upper bolts but leave the lower ones in place. Cover the fender. THEN rest the lower light bracket onto the fender. THEN remove the fastener securing the headlamp trim ring and remove the trim ring. THEN remove five screws that secure then headlamp assembly to the outer fairing and remove the headlamp assembly. THEN reach through the headlamp opening and loosen four locknuts on the two studs on each side of the headlight area which attach the fairing to the metal brackets inside the fairing. THEN remove the fairing by pulling it straight ahead away from the brackets.
Installation
First loosely position the outer fairing in place over the inner faring with the four studs going into the two brackets. Then install the five windshield fasteners through the outer fairing, the windshield and the inner fairing. THEN tighten the four stud nuts to secure the fairing to the brackets, being sure to have the inner and the outer fairing properly aligned at their outside edges. THEN position the light bracket so that the slots fit around the upper fork bracket bolts and thenalign the lower fork bracket mounting holes and replace the two lowering fairing mounting bolts through the light bracket and the outer fairing and the inner fairing and screw them into the lower fork bracket. THEN make sure that the rubber seal around the inner fairing is properly seated and not pinched and tighten the four fairing attachment bolts to 12-13 foot pounds (16 -19 Nm). THEN tighten the windshield screws to 4 inch pounds (0.45 Nm) but no more than this amount starting in the middle and working outwards on both sides. THEN reinstall the headlight assembly.
Jun 03, 2014 | Harley Davidson FLHTCUI Electra Glide...
Fridge washer GLWS1349AS0, have inner tub out, trunion lifted, not off yet due to slight rust. How do I change spin bearing and tub seal? thanks.
To remove the trunion totally reattach the inner tub to it and twist the inner tub,with the tub attached it gives you much more leverage to twist and pull the trunion off. After its off pull the small brass ring with the O seal in it up the transmission shaft and pop the tub seal off. To replace tub bearing remove the bolts on the side of the side of the outer tub off from the tub support and pull tub off of trans. shaft. to remove bearing flip tub upside down and remove the 2 screws from the tabs on bearing and turn tub back right side up and use a screwdriver on the top of bearing and knock it out of outer tub,push new bearing in by hand most of the way,being sure the tabs on bearing is lined up w/notches on tub and use old bearing placed on top of new one and drive it down all the way,reinstall screws into tabs. All the surface rust should be sanded off of trans shaft. Re install outer tub and secure with the bolts into tub support. push main tub seal into flange with normal palm pressure,install new brass ring and MAKE SURE O RING DOESNT POP OUT OF IT ( a little dawn,palmolive joy liquid dishwashing soap around inner part of o ring inside of brass ring will help it slip on easily) I use the old brass ring and press it over new brass ring to assist in o ring not popping out,once new brass ring is inserted ok and oring in place remove and discard old brass ring. Reistall trunion and inner tub ECT ECT ECT
Gene
Aug 12, 2011 | Frigidaire GLWS1349A Top Load Washer
Remove front headlight on 2005 ultra-classic
From the front is the easiest way-- 5 screws and it's out. 1 trim ring, 4 flange. The flange is down stream of the adjustment process. It's where the mounting bracket for the light meets the plastic outer fairing.
Good luck, i hope this helps.
Jun 30, 2011 | 2005 Harley Davidson FLHTCUI Electra Glide...
Need to remove the ring gear assy to replace the pinion shaft bearing
The ring gear is bolted to what is called a ring gear carrier, the carrier is bolted inside the rear end housing with two bolts on each side, it is shimmed on each side to adjust backlash and pinion depth so DON'T mix up the left and right carrier shims, once the carrier is out with the ring gear attached you can remove the pinion shaft and drive out the bearing races of the pinion bearings. You also need to remove the pinion flange where the drive shaft U-Joint attaches, just hammer it off with a brass faced hammer (a steel hammer will run the flange) once the large center nut is removed.
May 24, 2011 | Dodge Ram 1500 Cars & Trucks
Change headlight in 1995 cutlass ciera
Please don't forget to rate!
Composite Headlights
  1. Open the hood.
  2. Turn the bulb assembly counterclockwise 1/6 turn, pressing in firmly, until the flanges align with the slots in the retainer ring.
  3. Pull out the bulb assembly. You may have to rock it up and down slightly to loosen it.
  4. Disconnect the bulb base from the harness by lifting the plastic locking tab.
To install:
  1. Snap a new bulb into the wiring harness. Make sure the locking tab is over the lock.
  2. Install the bulb assembly by putting the small tab in the small notch in the retainer ring.
  3. Turn the bulb assembly 1/6 turn clockwise to lock it in place
Non-European Style
  1. Remove the headlamp trim panel attaching screws.
2. Remove the headlamp bulb retaining screws. Do not touch the two headlamp aiming screws, (at the top and side of the retaining ring), or the headlamp aim will have to be readjusted.
Remove the headlamp trim panel assembly from it's mounting location
3. Using a screwdriver, remove the retaining ring screws.
Once the retaining ring screws are removed, the ring can be pulled away
4. Pull the bulb and ring forward then separate them. Unplug the electrical connector from the rear of the bulb.
Pull the bulb out and unplug the electrical connector
To install:
  1. Plug the new bulb into the electrical connector.
  2. Install the bulb into the retaining ring and install the ring and bulb.
  3. Install the trim panel.
Mar 06, 2010 | 1995 Oldsmobile Cutlass Ciera
How do I remove the burr grinder for cleaning? Saeco Royal Exclusive
This is not a hard procedure, but you have to feel comfortable with DIY projects.
First empty the bean container. Vacuum out any remaining beans. Remove the philips screws from the hopper. Lift the hopper off. Vacuum any loose beans out. Remove the rubber gasket. You may clean this with a mild soap solution. Remove the grind adjustment lever- lift straight up with index fingers under the flange. Turn the outer ring with the holes counterclockwise, lift the center ring with the ears straight up when the outer ring is loose enough. The ring with the ears is the upper burr. Clean with a brush. Don't use water or other solutions. Vacuum the beans chamber and brush clean. Replace the upper burr ring matching the ears with the grooves. Turn the outer ring clockwise until it stops. Pull the inner ring to be sure it is locked. Now turn the outer ring back 13 clicks. Replace the rubber gasket. Replace the grinder adjustment lever- drop the lever flange inside on the outer ring with the lever grip loop over the top at #4. Press the flange with two fingers while supporting the outer ring from below. This seems tricky, but be patient. Replace the hopper and screws. Do any grinder adjustments while grinder is running with beans, it may take a few shots to be back at your preference grind! Good luck!
Dec 09, 2008 | Saeco Royal Exclusive 30153 Espresso...
Malibu ML88TL 88Watt Low Voltage Power Pack with Timer Logo
52 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
