Question about Toshiba BDX1100 Player
Wont detect dvd - Toshiba BDX1100 Player
The dvd player wont open and it isn't reading dvd's.
You will want to check in Device Manager to see if the device is even detected by the computer. Right Click My Computer, Properties, Click Hardware Tab and Device Manager. If it isn't recognizing the DVD drive then it is most likely bad.
Nov 30, 2011 | HP Compaq Presario SR5010 Desktop PC...
It wont detect a dvd on my acer aspire 5315 laptop
If your laptop won't detect DVD drive try and check connection first. Turn your laptop upside down and remove three maybe four screw (deepens on laptop) directly over a DVD drive and pull drive out. Blow some compressed air inside of laptop and check for anything abnormal on drive itself. Then put it back in and check if it works. If not it's either bad DVD drive or bad motherboard. Thanks and good luck.
Apr 17, 2010 | Acer Aspire 5315 Notebook
I have a emachine laptop and it wont load cds,dvds or games whats wrong with ut and how can i fix it
you have to verify if your DVD rom is detected in bios. Restart your computer and press F2 during boot. check if you see the DVD Drive is detected. if yes,exit and boot to windows if no.. your DVD is not detected and might be a motherboard issue or your drive needs to be replaced.
you can also try to clean your DVD lens with cotton or use a DVD lens cleaner
Oct 29, 2009 | E-Machines eMachines Desktop PC
Acer eXtenza 5620z , wont detect or play DVD
This is just a registry error ez to fix, click "start" "run" type in "regedit" click "ok" in the left field click the "+" next to "Hkey_Local_Machine" + next to "System" + next to "CurrantControlSet" + next to "Control" + next to "Class" then click on {4D36E965-E235-11CE-BFC1-08002BE10318} in the right field, "right click" on "Upper Filters" click "Delete" then "right click" on "Lower Filters" click " delete" restart PC. GL hope this helps you.
Jun 20, 2009 | Acer (KV.16X04.007) DVD Drive
Cd/dvd-rom drive E: not detected
plz check in the bios the cd rom is enable, then check the datacables try with a new data cable
Jun 19, 2009 | Acer Aspire 5315-2153 Notebook
Toshiba Satellite P205D-S7479 Drivers for DVD-ROM
Download new driver files of pioneer dvd drive fron internet.
Apr 17, 2009 | Toshiba Satellite P205D-S7479 Notebook
My windows xp dvd/cd burner wont burn
Hello
Does your DVD drive detect data dvd's or cd dvd's?
if not, it seems like a hardware problem and needs to be replaced...
Feb 21, 2009 | Microsoft Windows XP Home Edition
MY NTICD& DVD-MAKER7 WONT INSTALL, I HAVE NO DISC AS IT WAS ALREADY INSTALLED WHEN I BOUGHT IT
This is krishna.... I want to know are u using a desktop or a Notebook and also what kind of dvd player r using.....
it also depend on the hardware which you are using and also the operating system you are using like are using windows vista or windows xp.
check for the dvd player in my computer window, is it detected or not......... if detected uninstall and reinstall the drivers for the dvd player from device manager............ this will resolve the issue.
************if it is not detected then plz we need to do some of the changes from the registry files.........
Sep 13, 2008 | Computers & Internet
Toshiba BDX1100 Player Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
