A1302365A g1 board - Televison & Video
SONY KDF-60XBR950
The six blinks should have been the G1 board, double check your wiring and the check to make sure you have the 17V coming from the G1 board. If the problem has not changed it is possible you got a bad board.
May 24, 2014 | Sony Grand WEGA KDF-60XBR950 60" Rear...
My KDF-50WE655 will not turn on. No power light, there is power going in to tv.
Hi kevin,
If there's no led light at the front panel of the set, this is an indication that the problem is in the power supply board (G1 board), I'm assuming that you've confirmed that the AC source/outlet is live. To resolve this issue you must troubleshoot the G1 board board to isolate the faulty parts. If you don't have necessary tools and test instruments and can't troubleshoot the unit yourself, I would advice you to replace the entire G1 board or seek for an assistance of a qualified TV Technician.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Nov 07, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
I replaced the lamp and now my left speaker makes a sound as if its not conected correctly, then the tv turns off and the red light blinks seven (7) times, pauses and blinks 7 times again.
7blinks is an error code for "Audio Error". This kind of symptoms is an indication of fault either on the KD board AKA Audio board or the G1 board (supply line for audio board).
You have to isolate the fault between the two boards by measuring the supply line for the audio board. If the supply voltage is intact this is an indication that you need to replaced the KD board. If there's no output voltage from G1 board feeding the KD board, then you have to replaced the G1 board.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Oct 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hi I have a Sony KDF50we655 with 10 blinking red lights. Please Help !!
That can be caused by either the G1 or the G2 board. However the G1 board is more suspect for the 10 Blink error code. You can get both boards from www.tvrepairworld.com
Oct 11, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
The green light turns red and blinks 6 times before turning the power off. What does this mean.
Thats caused by the G1 board having an error . You can get the replacment G1 board from www.tvcircuitboards.com its listed under the Sony DLP circuit boards.
Aug 22, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
TV quit working when watching it, power light flashes red six times when trying to power on?
6 times blinking red light shows problem of missing DD 6Volts in G1 (power supply) board.
Please replace G1 board in tv to solve this problem, part number of G1 board is as follows..
A1060177A
Thanks.
Feb 05, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
G1: Well I cut my phone and the G1 logo appeared then ...
YOU MAY NEED A NEW "FLEX CABLE" OR LCD..THE FLEX CABLE HOLDS THE LCD TO THE BOARD AND ESPECIALLY WITH SLIDE PHONES LIKE THE G1 THEY SOMETIMES COME LOOSE OR GO BAD OVERTIME FROM SLIDING THE PHONE UP AND DOWN TO ACCESS KEYBOARD. CHECK YOUR AREA FOR A TECH.
May 06, 2010 | HTC G1
Spil water on tmobile g1
when ever your phone has been submerged, u must always turn it off straight away, take the back off and allow to dry for several days, do not put in tumble dryer! if a problem still persists then yes u will have to change circuit board, could be very costly, could also try ebay
Aug 07, 2009 | HTC G1
KDF-60WF655
this means replace the G1 board part # A-1060-177-A. some of these boards are not componet level repaired
Jan 20, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
the g1 board is your issue. 6 blinks means there is no or low b+ coming from the g1 board.
Oct 08, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
