Question about Sears 30" Freestanding Gas Range
Galaxy 7906070292 gas kitchen range
Top burners work, oven does not work.
My galaxy range model 790.60012604. The oven do not heat up . The element is lite up but the oven burner do not flame up which leaves a gas smell.
You need a new igniter, it may glow, but is probably not drawing the exact amperage required to open the gas valve decisively... You should also check burner tube and orifice for spider webs or other obstructions... Kenmore Range Stove Oven Igniter 316489402
Jul 05, 2016 | Galaxy Kitchen Ranges
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
I have a stainless 30" wide gas oven/range. The oven works and the top burners will spark but I do not get any gas flow to the top burners.
If it is just installed, your gas valve inside the range might be shut off. take out bottom drawer/broiler. Look for a switch in the back near the gas valve, it should be turned to the right.
Make sure the burner heads are positioned properly with the alignment pins.
Nov 15, 2009 | Whirlpool GS460 Gas Kitchen Range
Model MGR4452BDB range top burners work but oven
The igiter is bad and needs replaced . The glow bar has a crack and is not getting hot enough to open the oven valve allowing it to ignite.
Nov 01, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't work on gas with electric ignition stove
The glow bar for the bake burner is bad, needs to be replaced. Remove oven bottom to get to it, and also the utility drawer.
Feb 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas range
I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
Can you help ? Thanks, Tom
Apr 07, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Sears 30" Freestanding Gas Range Logo
11 people viewed this question
Top Sears Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Sears Kitchen Range Expert? Answer questions, earn points and help others
