Question about Aube Technologies TH108PLUS Aube TH108PLUS Electric Thermostat
LO on the screen - Aube Technologies TH108PLUS Aube TH108PLUS Electric Thermostat
Oven thermometer only displays lo
I just had that LO reading. Pulled back on the tip of the thermometer. Seems I had it inserted into my turkey too far. Probably up against a bone or too close to the center. Good luck! Happy Thanksgiving 2016!
Dec 25, 2013 | Farberware New Classic Alert Oven Probe...
On start up LO appears on screen
the LO is just saying low tempeture it will go away in a min or 2 then should be able to use or try to replace the batteries
Aug 12, 2013 | FMP Cooper-atkins Versatuff Plus 93867k...
System lo bat
Most likely it's your back up battery. It should be with the panel in a metal box. If you have a wireless system the zone number will pop up on the screen at the same time the "lo bat" does.
Oct 29, 2012 | Honeywell Ademco 6160 Alpha Keypad Vista...
Screen has message "spell lo-bat"
Spell check is on, the batteries need replaced and in single space.
DickyO
Jan 03, 2011 | Lexmark Wheelwriter 3500 Typewriter
Flashing LO
"LO" means a "Limit string open error" has occurred. See the owners manual for the many causes and possible solutions. Owners manual found here. http://www.haywardnet.com/products/Manuals/pdfs/Manual225.pdf
Apr 08, 2010 | Hayward 350K BTU H SERIES HEATER DRAFT...
MI IPOD MOD A1199 4GB NO LO RECONOCE MI PC
I have the Ipod nano 8g and the screen lights up but but get no menu and can't play anything.. I just go this ipod.
Apr 08, 2010 | Apple iPod nano
0.5=log Io/It find Io/It
Hello
A set a parentheses would sure help remove any ambiguities.
I assume your equation is 0.5 =log(lo/lt)
There is an equivalence
y=log(x) is equivalent to x=10^y
You can write
10^(0.5)=10^(log(lo/lt))
But 10^(log(x))=x, thus
10^(0.5)= lo/lt
and lo/lt=square root of 10
Here is a screen capture to convince you.
Hope it helps
Oct 25, 2009 | Casio FX-300MS Calculator
Malfunction D80 showing erratic "Lo " message,
if you're in a P mode it means it in low light condition. whne you see the Letters "LO" and take a shot it woudl take time before the camerea releases the shutter because it's automatically exposing the image and exposure may take longer depending on the lighting condition.
Jun 01, 2008 | Nikon D80 Digital Camera with 18-135mm...
Aube Technologies TH108PLUS Aube TH108PLUS Electric Thermostat Logo
44 people viewed this question
Top Aube Technologies Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an Aube Technologies Heating and Cooling Expert? Answer questions, earn points and help others
