Question about Radio Shack Pro-2052 Scanner
Display backlight not working on my pro2052 scanner
I am looking for software to program Uniden SPU480K Handie Talkies
http://download.cnet.com/scancat-gold/3000-2130_4-10041190.html Scancat-Gold for Windows is an 'All in One' computer program to take control of your Police Scanner or Shortwave Receiver. Scancat supports all radios within one program. We support most popular manufacturer's radios such as: AOR, ICOM, KENWOOD, JRC, UNIDEN, YAESU RADIO SHACK. New trunk tracking support has recently been added for models such as the BC780, BC245, BC895 Uniden and PRO2052 Radio Shack. Hope thie helps
Aug 04, 2011 | Computers & Internet
I have a uniden bc340crs scanner that is 1 yr old. my backlit window does not display any of the info for my scanner. i want to reprogram and the 2-9-hold thing does not work even after trying ronnie...
This is how you control the back light display on your scanner.
SNOOZE/Backlight - Backlight: Tap the snooze button to turn the LCD backlight on for 15 seconds. Press and hold to permanently turn on the backlight. Press and hold again to turn off the backlight.
Here is a link to the users manual as well. http://www.uniden.com/pdf/bc340crsom.pdf
Mar 14, 2011 | Uniden BC340CRS Base Scanner
The backlight to the display no longer works. The "bulb" seems to be burned out. Is this going to be a cost-effective repair...?
The backlight in your scanner is an 8volt bulb, but your scanner is 10 years old, and the exact replacement is no longer carried by radio Shack. You can, however, replace it with a 6volt 25ma bulb, Radio Shack catalog number 272-1140. Replacing it is fairly simple if you're at all handy with electronics and a soldering iron. Contact your local RS to purchase or order the bulb, and I'm certain that they can have it installed if you're not up to trying it yourself.
Bill B
Listening in since the 60's
Sep 29, 2010 | Radio Shack Pro-2052 Scanner
HOW DO I ENTER FREQUENCIES AND SCAN.
Unlike most every other RS scanner, the 2052 has Uniden firmware, and is fully PC controllable. If you have the cable and CD its easy or download the software here. http://www.qsl.net/kd5lmy/software1.htm
If not, download the manual here.http://mirror.bachelorsgrove.com/pro2052/
Aug 02, 2010 | Radio Shack Pro-2052 Scanner
Very dim light on my pro 2052.
Display or backlight? If it's the backlight, you need to replace one solder-in bulb. Radio Shack part number 272-114 (5v, 25mA) will work. If it's the dispay you need to contact the Shack for a replacement.
Bill B
Feb 26, 2010 | Radio Shack Pro-2052 Scanner
Beoken backlight
u kant
u will have to get another screen 4 ur psp
Nov 18, 2008 | Sony ACY-BR81/OB
Backlight
hi
ther is only 1 option for this unit
http://www.uniden.com/pdf/BC72XLTom.pdf
page 50
-Using the Display Backlight-
To turn on the display light for easy viewing at night, press . The display lights for 15 seconds. To turn off the light sooner, press again.
other models have more options but this one doesnt
same for the 92xlt
D
Oct 10, 2007 | Uniden BC72XLT Handheld Scanner
How do i get the backlight on and off
Follow this link for the manual http://support.radioshack.com/support_electronics/doc61/61170.pdf That model does not have the ability to turn backlight on or off, your display may be on it's way out. Try resetting it first though, refer to page 66 of manual. Good Luck
Aug 11, 2007 | Radio Shack Pro-2052 Scanner
Radio Shack Pro-2052 Scanner Logo
104 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
