Question about NordicTrack Exercise & Fitness
NORDIC TRACK 2050C BELT SLIPPING - NordicTrack Exercise & Fitness
SOURCE: Nordic Track Treadmill Viewpoint 2800 : The belt
It needs to be adjusted as shown in your owners manual.
There are two allen screws located at the back end of the treadmill. That's where you adjust it. 3 - 4 inches of slack midpoint is just right
Posted on Nov 23, 2009
  • 3 Answers
SOURCE: I have a Nordic Track treadmill C1800. When first
You have 1,2 or maybe 3 problems. 1st is you need to remove the cover over the motor. The belt that the motor turns may be slipping. You need to loosen the bolt that keeps the tension on the drive belt. Push down to tighten manually and then tighten bolt. While your in there you should check the drive belt for wear. If you have used the treadmill a lot it may need replacement. $20 from readmilldocter.com The walking belt if badly worn can be replaced for like $99 but probably is fine. put all back together and tighten tension. Should be able to lift walking belt 3 to 4 inches from center sides. Any less and its too tight. Its probably better to just replace the drive belt anyway. This should work. Do not over tighten ever. This is the cause of most problems.
Posted on Feb 20, 2010
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
SOURCE: Have a nordic track exp 1000x treadmill and the
my nordictrack exp1000x doesn't elevate anymore, what can be the problem and how can i fix it?
Posted on Oct 29, 2010
SOURCE: our belt is slipping on our nordic track c1900
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Posted on Jan 03, 2011
Have the Nordic Track ASR 630. The belt slipped off. We fixed that. Now, the display will come on but blink off and on and then go off.
Check whether the belt is over tighten or not. If so by consuming over current this problem can occur. Try to loose the belt and check whether display shows the same symptom. If not then tighten the belt without become over tighten.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 29, 2016 | Nordic Track Exercise & Fitness
Why would the motor belt keep slipping off
Usually if a belt slips off the pulleys, it's because of misalignment.
The belt is not tracking true, pulling to one side.
Jun 05, 2014 | Nordic Track Nordictrack C2100 Treadmill...
How to adjust belt?
If you are adjusting the walking belt that much (7 complete turns) it sounds like the drive belt the small rubber belt from the motor to the front roller is really loose. You should only have to adjust the walking belt 2-3 turns max... you do not want to prematurely stretch your walking belt!
May 14, 2014 | Nordic Track Exercise & Fitness
I have a Nordic Track Commercial 1300 eliptical that started slipping when we used it. We tightened the belt but it didn't help. What else could be wrong?
Step 1
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Step 2
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Step 3
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.
sincerely. Merry Christmas.ernesto cuadra
Dec 18, 2011 | Nordic Track Exercise & Fitness
Nordic track c2000 belt slips
I would try to tighten the rear roller a little and see if that helps.
1 start the treadmill and operate it at 1.5 mph then hild onto the handle bar and plant your foot against the belt at the front. If it slips tighten the roller 1/4 turn on each side. Then try the slip test again and repeat the process, do not tighten it too tight that will cause the belt to fold in teh center and be ruined. You May quite possible need a new belt. Take the belt lose and look at the underside and see if it;s glazed (shinny) or has pieces missing under the center of the belt, if so replace the belt and also clean the rollers front and rear, also flip the deck over it shoudl have a wax coating on the other side if that hasn;'t already been done.
Oct 23, 2011 | Nordic Track Exercise & Fitness
My Nordic Track A 2050 is slipping. At first I noticed it slip from time to time in my 45 minute workout, but at the end, it was like I was on ice. I love this treadmill, is there a way to fix it?
Have you tried adjusting the rear roller bolts with an allen wrench? That usually works for me.
Unfortunately now I have a slipping problem that tightening the belt via the roller bolts doesn't fix. In fact, I feel as if the belt is too tight as it only lifts about 2" instead of the recommended 3-4". Hope we get some other ideas here!
Dec 21, 2010 | Nordic Track NordicTrack Treadmill, A2550
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
May 17, 2010 | Nordic Track Exercise & Fitness
Feb 05, 2010 | NordicTrack Exercise & Fitness
Our belt is slipping on our nordic track c1900 treadmill, how do i fix it?
Sep 17, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
12 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Electro Med Services...
Jerry Kramer
Jerry Kramer
Steve P
Steve P
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
