Question about Logitech Cordless Mouse
Logitech m560 what do all the buttons on the mouse do
How do i use the staples wireless optical mouse with my chromebook?
Wireless mouse and keyboard are supposed to work on chromebook. It is supposed to work just by inserting USB dongel in port. If won't work, test it on a Windows or Mac computer. Wireless mouse and keyboard are supposed to work on chromebook, see customers report at amazon
Amazon com Customer Reviews Logitech Wireless Mouse M560 for Windows 7 8...
But, if works on Windows, it simply won't work for chromebook. No way!
Mar 10, 2015 | Staples Wireless Optical Mouse, Silver
Logitech mouse is'nt working
You might try re-syncing the mouse with the wireless sender. Push the button on the sender (plugged into usb port usually) and then push the button on the bottom of the mouse.
Aug 02, 2010 | Logitech Cordless Mouse
3-Button Cordless Optical Scroll Mouse : logitech wireless mouse flash card broken can it b...
At logitech they warranty all mice for 5 years, it's an hour on the phone, hold, etc. once the tech has all the details and realizes it's really broken instead of you don't know how to use it, they send you a replacement.
May 16, 2010 | Logitech 3-Button Cordless Optical Scroll...
How to replace the batteries of Cordless logitech mouse of my pc
If it is a LOGITECH V 220 it will be at the bottom of the mouse.
Regards, Kesav.
Mar 01, 2010 | Logitech MediaPlay Cordless Mouse
I have a logitech cordless mouse that plugs a usb device into the usb port for it to work. I've been reading through solutions to fix problems with these mice and most of them say that the usb device was a...
If its a logitech look at the model number of the mouse your using go to logitech.com support type in your model number and download the logitech software for your specific os and mouse. You'll notice a big difference compared to just having the drivers installed.
Jan 05, 2010 | Logitech Cordless Mouse
How do I set up on Logitech wireless mouse??
You have a small button on the us plug of the wireless logitech mouse you have to put both the mouse and the USB plug to see each other clearly then push this button and a red light will blink until it stops alone , now your mouse is ready to work
Nov 18, 2009 | Logitech Cordless Mouse
Changing batteries on a logitech lx5 mouse
turn off the mouse using the switch on the bottom.
press the battery door release button on the underside of the mouse, towards the back.
that should release the battery door, which is the top part of the mouse, where your palm would rest.
the mouse takes 2 AAA batteries.
Feb 04, 2009 | Logitech Cordless Click! Mouse
I have a Logitech wireless mouse that I cannot seem to get working on the computer i have a logitech cordless mouse JNZ201962 which i cant seem to operate even thou it says the drivers are installed
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Jan 16, 2009 | Logitech Cordless Mouse
Logitech Mouse Not Working
Normal 0 Are your batteries in the Keyboard and mouse good?
You probably have gotten it working by now but here is a way to get it work if not.
Press the Receiver button a(and the lights will start flashing, then if its the Keyboard that isn't working, press the small RESET/CONNECT button on the back of the board to connect.
If its the MOUSE do the same except push the small RESET?CONNECT button on the back of the mouse to connect. Then they should work properly. Hope this helps. Bud
Dec 23, 2008 | Logitech S 510 (967555) (DH967555)...
Can't reset my cordless Logitech mouse
you should hold the reset button on the receiver for 5 seconds. let it go and immediately press the reset button on the mouse once. If done in this order it should be ok.
Aug 23, 2008 | Logitech Cordless Mouse
Logitech Cordless Mouse Logo
18 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
