Question about Slendertone Fortex
Slendorone contols won't letme set the level above three, it gets there ad just beeps
CONTINOUS BEEP WHEN COMPUTER IS TURNED ON
To do this properly I need to know which model your computer is - is it an eMachines MB.NBK09.003 Motherboard El1850 Desktop S775 G41T-Ad ? I need this to try to establish the BIOS seller and version. You might try finding the BIOS version by (continuously) tapping the F1, F2 or esc key (or possibly another)immediately after you turn on. The "splash screen" that appears aftrer you turn on may have some lettering which tells what key to enter the BIOS.
In the absence of this information here are two suggestions
EMachines that beeps constantly and won boot up
if it is the above it is serious and the computer will need serious (difficult) repair, or main board replacement or whole unit replacement (by which I mean new computer)
The other suggestion was about the RAM not being properly in place, but I doubt this as this usually gives a different beep code
19.January.2016
Jan 19, 2016 | eMachines MB.NBK09.003 Motherboard El1850...
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
No video on asrock p4i45G motherboards
Hello the homepage is here:
http://www.asrock.com/mb/Intel/P4i65G/?cat=Manual
3 short beeps: base 64 k ram failure.
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Read more here:
http://www.computerhope.com/issues/ch000996.htm
Beep codes:
http://www.computerhope.com/beep.htm
The fault could also be: power supply, or bad capacitors on the mainboard.
Good luck
Nov 26, 2012 | Asrock P4i65G Motherboard
Where is the radiator cap to add stop leak
Lift the hood. In the upper right hand corner is the overflow fill tank. If you want to put it in fast reach down the right side of the radiator(when it's cool) unscrew the small plastic petcock and drain a gallon or two of antifreeze into clean pan. Replace petcock. Open the cap on tank and add stop leak. Fill back up with antifreeze. Now would be a good time to change it. Go to Napa and buy the original antifreeze the car came with Zerex G5. Mix 50/50 with distilled water.Fill to just above cold line and start engine keep adding mixture till it won't go down any more. Replace cap and watch level for two or three days of driving add mixture after engine is cold12_2_2011_3_42_50_pm.gif
Dec 02, 2011 | 2005 Chrysler Pacifica
Computer won't boot and beeps: BEEP pause BEEP BEEP BEEP
In case you have AMI BIOS, it is a computer RAM (memory) related issue.You can remove added memory, reseat memory, swap memory location or try memory from other computer
Jul 05, 2011 | Computers & Internet
I would like to uninstall the google chrome on my computer cause it does not work properly cause it does not let me get in to the inter net with it so i want to take it off my computer
On Windows Xp go into the contol panel and click on add/remove programs.
click google chrome and then click remove.
on Windows Vista/7 go to my computer/add/remove and do the same as above
Jun 04, 2011 | Computers & Internet
In three days my electode is clogged up my salt build up.so I get a low salt alarm
ok, it is time to stop guessing on how much salt to add or take out.
You need to be as close to 3000ppm as you can
anything under 2700 and you will not generate enough chlorine. any thing above 3500 and you can go cloudy, have build up, or just plain taste terrible.
you need a test kit for salt that reads in #'s not color
the color salt kits have too much varience
If you are over, drain 20% of the pool and ad fresh water keep doing this till you get close to 3000ppm
If you are under then ad the amount of salt stated in the test directions.
Once at 3000 clean your cell again.
you should be good to go
Dont forget that once at 3000 you must keep an eye on the level because of rain and adding water for splash out
Aug 29, 2010 | Intex Automatic Salt Water System for ...
Check oil level warning comes on. Oil level is OK. This warning is intermittent.
first thing is check the oil pressure not by the instrument panel if ok then panel is out if not its the sensor or oil pump Try this replace the temperature sender with the new green model and oil light will disappear no more three annoying beeps.
Dec 24, 2009 | 2000 Audi TT
Error code OE will not finish cycle
Hi
Thanks for using FixYa. A fault is detected in the water level sensor. Data (frequency) shows the water level is at or above the overflow level. Try entering the service mode by pressing the Spin and Temperature keys for three seconds or until the control beeps.
NOTE: The washer must be ‘ON’ before Service Mode can be entered.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Maytag Neptune MAH9700 Front Load Washer
Motherboard beeps three times, computer won't boot up
Your computer is experiencing memory problems. Turn power off, remove and reseat the memory chips, and try it again. If not successful, try different memory chips. Also could be power supply problem
Jun 13, 2009 | Gateway 506GR PC Desktop
Slendertone Fortex Logo
124 people viewed this question
Top Slendertone Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you a Slendertone Exercise and Fitnes Expert? Answer questions, earn points and help others
