Question:
Why won't my unit acquire satellites?
Answer:
There are a several different factors that can cause a
GPS unit to not acquire satellites:
- If your unit is indoors, it may not acquire satellites.
- If your unit is trying to acquire satellites for the first time, it is normal for it to take a while to establish its initial position.
- If you have just finished updating the software in your unit or you have performed a master reset, your unit may take longer than normal to acquire.
- If your unit has traveled a long distance while turned off or not tracking your travel, it may take a longer period of time to acquire.
- If your unit has not been used for an extended period of time, it may take a longer period of time to acquire.
- If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, you may need an external antenna.
If your unit is not acquiring satellites, it is recommended that you place the unit in a stationary position where it has a clear view of the sky. In some cases it may be necessary to take the unit outside of your vehicle as certain vehicles inhibit the unit from acquiring satellites. As the unit receives
signal from the satellites, it will begin to lock on to them individually until it has acquired enough information to establish your position.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software. You can do this using our WebUpdater program which can be found at the following link:
http://www.garmin.com/products/webupdater/howtoinstall.jsp
