Question about Saws
Craftsman radial arm saw
Just bought a RAS, model 133.198250. I removed the cover to the digital display and discovered that the wiring is broken for the miter encoder. How do I remove the miter encoder to replace it. I can't find a happy medium between adjusting the elevation so it moves easily without being able to move the arm. It's one or the other. I suspect something is worn out and needs to be replaced. A possibility related problem is that I can't square the blade to cross cut. The adjustment involves the same bolts as those used to adjust the elevation resistance. Is there such a thing as a field service manual that would allow me to take the saw apart?? It needs some TLC from top to bottom... Thanks.
Schmead10
  • 650 Answers
SOURCE: Need Owners manual for older Craftsman Radial Arm
Here is a site to have the manual Emailed to you
http://www.sawmanuals.com/ Hope this works for you.....Please rate.......
Posted on Apr 14, 2009
SOURCE: I need a diagram of a Craftsman Radial Arm Saw base
I persevered and finally solved the jig saw puzzle of pieces. The base is now assembled and just waiting for the saw body to be remounted. Thanks everyone for looking at this post.
Posted on Sep 06, 2009
al_kupchella
  • 843 Answers
SOURCE: need replacement parts - accessories
If the kickback arm you seek is the type that is a round bar with pointed fingers on the bottom, I had the same problem. (different model DeWalt) I gave up trying to find one, and finally just made one. It was pretty easy, and works very weill I bought a piece of steel rod (1/2 inch I think) a steel repair plate (from which I cut a pair of tear-drop shapes with a hacksaw and file) a 1/4 inch hex-head bolt (which had about 1 inch not threaded) and a 1/8 inch roll pin. I looked at various pictures on the web to determine the shape of the teardrops. I drilled a 1/4 hole in the 1/2 rod. I cut the threads off of the 1/4 bolt so it was still long enough to accept the 1/2 rod, the two teardrops, 2 washers and the 1/8 roll pin. Then I put an 1/8 hole in the bolt allowing enough clearance so that the teardrops would swing freely. It works like a champ. One minor flaw is that with only two of the teardrops (instead of several) and being separated by 1/2 inch, it would be possible to make a skinny enough rip that only one teardrop would contact the board being ripped, leaving the other peice unguarded.
Posted on Jan 27, 2010
  • 7 Answers
SOURCE: craftsman radial arm saw 113-197751 wiring diagram needed
A friend just inherited a model 113.197110 and we are in the process of trying to restore it. I can draw you the wiring connections if you haven't figured it out yet.
Posted on Apr 22, 2010
agent91
  • 2100 Answers
SOURCE: I have a craftsman table saw model 137.248830 and
You should have 4 bolts holding the trunnion on to the table, just loosen these bolts up a little, tap the trunnion with a hammer, the right way, put a straightedge on the blade fully extended and measure across the table to a dado slot, front and rear, tap it till it is exact, tighten bolts and check again. This should do it. You can check your fence the same way. hope this helps.
Posted on Jul 26, 2010
Craftmans radial arm saw model 113.198111 short down within 3 to 4 seconds and pops circuit breaker
I purchased a Master Craft radial arm saw brand new and made three cuts and it did the same thing. I took it back to the store where I bought it and they gave me another new one. Something in the motor had burnt out.. You could smell it also.
Sep 09, 2014 | Craftsman Radial Arm Saw, Power Switch,...
What is the horse power for my 12' radial arm saw model 113.19790
I think it's 1/2 or 1 HP. I'm not 100% sure. I suggest you email Sears.
Jul 31, 2014 | Craftsman Sears Radial Arm Saw Arm 815688...
Craftsman radial arm saw 113-197751 wiring diagram needed
Apr 04, 2010 | Craftsman 10" Table Saw
I just bought a Sears radial arm saw. Model
Go to searspartsdirect.com and list the model number which brings up drawings of all parts and usually a manual. Hope this helps!
Feb 05, 2010 | Saws
Sep 05, 2009 | Craftsman Saws
Craftsman radial arm miter saw parts discontinued
Any hardware or home improvement store will have a replacement.
Jul 22, 2009 | Craftsman Saws
Saws Logo
186 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
