Question about Bosch Dishwashers
I have a bosch dishwasher model shx98m05uc/49 and need to tighten the handle. Hoe do I access the handle screws
Thank you, Kim
  • 641 Answers
SOURCE: Access to Bosch dishwasher pump
To access the pump, first bail and sponge out any water in the machine's tub. Then tip the machine over on its front, using a heavy blanket or pad to protect the dishwasher's finish. Remove the back service panel. The pump is usually located along the bottom. Good luck!
Posted on Aug 28, 2007
  • 171 Answers
SOURCE: My bosch dishwasher handle is loose
Hi rsouthwick,
I'm Harvey the Master Plumber.
You want to know how to tighten a bosh d/w handle?
Easy! open the door and look around the perimiter. You'll see screws on the right and left, they hold the front panel on. Simply remove them. The front panel is off and you can tighten away!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
SOURCE: GE Monogram ZBD0710 Dishwasher
THIS IS THE SOLUTION!
I was having the same problem with my Monogram dishwasher and oven.  Here's what to do.  You must fully remove the handle from the appliance.  Down the barrel of the standoff is a hex screw that, when tightened with an allen wrench, will draw the standoff tight to the handle again.  There is no need to remove the end caps.
Posted on Nov 26, 2008
SOURCE: Bosch Door Handle: Loose
I had the same problem with my Bosch dishwasher.I came to this web site to find out how to get the door off.I took the experts advice,placed 4 pillows on the floor in fromt,opened the door,took out the screws and the front panel dropped down.It was so easy,the plastic spacers stayed in place.I put a little J B weld on the handle screws and tighted the handle and put everything back together,12 minutes tops.Thanks for the help,thankful in Georgia
Posted on Feb 21, 2009
SOURCE: loose door handle on bosch integra ltd. dishwasher
you can loosen the inside of the door with a small torx screwdriver and lift it up far enough to get to the screw that holds the handle from the inside. I did this with mine about 1 year ago.
Posted on Oct 14, 2009
Handle on my SHU 9950 is loose. I don't see a set screw or anyway to tighten it. How do I do it?
sometimes you have to take the oven door apart to access the screws that hold the handle on. I have not looked at this model but most ovens have screws on the top of the door when you open it. Be careful though and pay close attention to how it goes together because they can be tricky.
Nov 10, 2010 | Bosch SHU9950 Dishwasher
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Door handle need to be re tightened. Do you hav...
if its just the handle itself it sounds like the fixing clips have come adrift or broken off,the handle strip will need replacing if its the whole console thats loose remove the outer door cover this will give you access to panel screws and may allow you to see more of the handle fitting inside.
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Front handle is loose on my bosch dishwasher.., how do I tighten it?
remove srews that hold inside panel should give you acsess to handke tighten and replace screws
Dec 06, 2009 | Bosch SHX43M05UC Built-in Dishwasher
Loose door handle on bosch integra ltd. dishwasher
Aug 30, 2009 | Bosch Integra® 500 SHX46L Built-in...
Hi,I have a Bosch dishwasher SHY 66C02 UC and the handle is loose. What do I need to remove to get access to the front panel? Thanks, Will
u have to remove the torx screws on lhs and rhs of the door and a also at the top of the door.once u remove them the front panel will come out and u can tighten the handle screws.good luck.
Aug 18, 2009 | Bosch Dishwashers
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Hi rsouthwick,
Thank you,
Sep 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Jun 09, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Mar 27, 2008 | Dishwashers
Dishwashers Logo
23 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
