Question about LG LSN121HSV2 11,200 BTU 20 SEER Ductless Heat Pump Air Conditioner Air Handler"
Cooling light flashing 5 times heat pump
Cooling lights flashes 5 times no heat no nothing
SOURCE: turns off and power light flashes
Cleaned filters, changed batteries in remote, prayed a bit, and it worked - no idea which activity was the remedy!
Posted on Oct 04, 2009
  • 587 Answers
SOURCE: Gold Star mini split heat pump 24,000
On a heat pump the difference from heat to cool is the reversing valve.
In cooling or heating the Y1 terminal will always be energized, this is the contactor.
Depending on brand the reversing valve will either be energized in Heat or Cool. At the outdoor unit check to see if the reversing valve is getting 24 volts in cool, if not check to see if it is getting 24 volts in heating. The easiest way to check if the reversing valve is shifting, is to feel the big copper tube, (it is not the suction line on a heat pump) this is a refrigerant vapor line. It will be cold in cooling and hot in heating.
Check your thermostat installation instructions and heat pump installation instructions to determine the proper terminal designations for your heat pump and thermostat. There are some brands out there that use the B terminal as common to the 24 volt circuit, so you have to check the wiring and make sure this is not common.
If it is energized in Cool then the Y1 and O terminal will be energized. You will have 24 volts from common usually the C terminal to Y1 and O.
If it’s energized in Heat then the Y1 and B terminal should be energized. You will have 24 volts from common usually the C terminal to Y1 and B.
If you get heat when you’re calling for cooling or vice versa then switch the wire between the B and O terminals.
Posted on Feb 10, 2010
hvac1960
  • 2133 Answers
SOURCE: Operation and timer light flash
Please cancel your timer setting by reset the power. And also remove battery from your remote and reset it. Now start your unit.
Posted on Dec 14, 2010
hvac1960
  • 2133 Answers
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Posted on Jan 03, 2011
hvac1960
  • 2133 Answers
SOURCE: Please help i got a LG r12awn split and the
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor. Thanks.
Posted on Feb 05, 2011
What does the snowflake mean on a Honeywell thermostat in cooling mode. Also had the problem in the heating mode.
The snowflake means it's cooling. If the outdoor unit is not running then the problem is likely outside.
May 21, 2017 | Honeywell Heating & Cooling
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
Model A12AWU-UF7
That is an alert code. Most heaters require forced air venting, and some use a vacuum switch to test for that airflow before igniting gas flame.
May 07, 2014 | Heating & Cooling
Fujitsu heat pump flashing code?
Test the fuses for the outside unit.
Aug 29, 2017 | Heating & Cooling
Cooling light flashes 4 times. Unit appears to shut down.
Your documentation or electrical cover may refer to 4 flashes. What does it say?
Oct 25, 2013 | LG LSN091HSV / LSU091HSV 9,000 BTU 20 SEER...
Not cooling and shutting off, indicator light flashes
the outdoor indictor light on my lg split comes on after some minutes on the one inside and the cooling has reduced please can any1 tell me what the problem is
Jan 18, 2013 | LG LSC121PMA Split System Air Conditioner
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
The cooling light is always on, and it takes about 90 minutes to dry a load.
In normal operation as the dryer is drying the "drying" light flashes and the "cooling" light is on steady until the 5 minute cooldown at which time the "drying" light stays on steady and the "cooling" light flashes. click on this lg link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6253
Nov 18, 2009 | LG DLE7177 Dryer
LG LSN121HSV2 11,200 BTU 20 SEER Ductless Heat Pump Air Conditioner Air Handler" Logo
24 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
