Question about RCA Audio Players & Recorders
Can't get audio or video thru surround sound rca rt2781h
I can get the dvd to work thru the surround sound but not the tv
MrBob84
  • 90 Answers
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Posted on Feb 13, 2008
  • 47 Answers
SOURCE: How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Posted on Mar 09, 2008
  • 1779 Answers
SOURCE: CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Posted on Apr 04, 2008
toddg
  • 171 Answers
SOURCE: I just bought the 52
Is the volume on the dish network device turned all of the way dowm?
Is the dish network connected to its pwn input on the SS system and did you turn the SS system to that input ?
Are you using the analog input (red and white) cables to the input from the TV to the SS System?, not from the SS box? This is not the correct setup?
Posted on Sep 25, 2008
SOURCE: Wharfedale LCD37F1080P and external surround sound
  1. hi here is what you do go into menu go to feature thento ext 2 out then press right blue button on remoteand find the ext you need make sure your tv volume is turned down make sure your surround sound is on and turned up wait and you will here your sound when you have the right ext i have hdmi lead in ext 5 so it ext 5 that will show in the feature menu i hope you find your problem solved allan
Posted on Sep 27, 2008
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
How to set up to my tv
Ok...sorry it took me so long to get back to you...Check the back of you tv and look for RCA jacks for audio and video out...There should be a yellow one for video..a white one for audio left(L) and a red one for audio righ(R)...you may not need the yellow one...now look for any inputs on the rear panel of the surround sound system...They can be marked (AUX)...they will work..once all of these are located...you will need an RCA patch cable long enough to reach from the tv to the surround sound receiver...once done...turn on the tv and the surround sound.With the remote from the surround sound remote...switch between the input sources..maybe (AUX) until you hear your tv sound come through...then you adjust the sound as needed...Assuming the DVD is built in to the surround sound system...your DVD sound will come back when you play DVD's...All connections and cables are color coded so you should have no problem connecting everything....Good luck....let me know how it goes,,,,I hope this was helpful....PEACE.....
Jan 05, 2012 | Audio Players & Recorders
How do i hook up mt audio speakers to my tv for surround sound? klh 403
If I understand correctly form your question,you can not hook them unless your TV has 5.1 surround sound amplifier built in...Does it ? I doubt so..
in order to get a surround sound from your TV you need a 5.1 /7.1 DVD/Receiver and you can connect your TV to listen it thru Receiver ..Here is how you can do it..
** connect "Audio Output " as either :"2xRCA jacks"or "Optic cable output" or "HDMI "connector " of your TV ,
** to "RCA input jacks " or "Optic Cable input"
or if you have "HDMI input" of your DVD/ Receiver
** than just switch to respective mode on
Receiver corresponding the connector you have used on the back of Receiver ..
There you go..your Tv sound are on the
DVD/receiver as SURROUNDING SOUND .
By this means ,whatever you watch on the TV
will come thru your
Receiver
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 06, 2011 | Audio Players & Recorders
MY TV ONLY HAS SOUND WHEN IT IS HOOKEDUP TO THE DVD PLAYER AND A SURROND SOUND SPEAKER BUT NOT FROM THE TV OR WHEN HOOKED UP TO THE SPEAKER ON TV OR XBOX
Hi,here is the solution......
Since you successfully connected your
DVD /Receiver to play video on TV (one way only ) ,here is the second reverse action to listen your TV on DVD /Receiver
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV ,
** to "TV input "or "AUX input" or "Optic Cable input"
of your DVD /Receiver (whichever you want based on the necessary cables on your hand )
DVD /Receiver corresponding the connector you have used on the back of DVD /Receiver ..
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
There you go..Both Tv and Xbox sound are on the
DVD /Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your DVD /Receiver SURROUNDING SOUND .
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
Jul 03, 2011 | RCA L46WD22 Television
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
Jun 25, 2011 | Audio Players & Recorders
I would like to know if my ht 3913 will work thru the TV sound, I have no problem with it working when I'm using the DVD player to watch movies, but I would like to hear the TV thru surround sound
Directly , no, since the tv sound is always just on 2 channels. But you can convert it in the receiver to surround by activating either the SRS Surround or the DolbyProLogicII options on your receiver.
Aug 19, 2010 | Audio Players & Recorders
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
21 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
