686 amibios 1999 zg96
I am putting this motherboard into an alienware tower, and I can't figure out how the f panel is connected
5 Suggested Answers
sigma_shiva1
  • 188 Answers
SOURCE: front panel hook up
HEY MAN U HAVE SERIUS PROBLEM... OK THIS MAY SOLVVE U R PROBLEM....JUST DOWNLOAD U R MOTHERBOARD USERS MANUAL...AL CONNECTIONS ARE GIVEN THERE..EVEN FRONT PANAL SETTINGS TOO.... BEST REGARDS MAIL ADD- SIGMA_SHIVA1@YAHOO.CO.IN
Posted on Oct 10, 2007
  • 230 Answers
SOURCE: Is It required to connect Tower Front Panel I/O to Motherboard
The only front panel pins you need are for the power switch. Track them from the front panel to the connector and plug them upto the 2 pins for power. Dont worry about polarity it can go either way. The connector may look a little odd but it will work just fine. In the past in that situation I have cut the plastic in such a way I have separated the different connections but its not worth the trouble in my opinion.
Posted on May 06, 2009
benwabnick
  • 2404 Answers
The power button on the front panel would definitely need to be hooked up to the motherboard so you can power up the computer.
If you have any usb slots or a media card reader on the front panel, or both, then you would need to hook those up as well, otherwise the main one you need to connect would be the power button.
Posted on May 23, 2009
  • 11800 Answers
SOURCE: I need motherboard driver and
Simple test: disconnect all disks, remove the BIOS battery for 10 minutes, put it back (this resets everything to default factory settings) then try to boot in the BIOS - if it fails then the motherboard is defective - no BIOS update can fix that.
The board is dead, time for a new pc.
Posted on May 02, 2011
Need wiring diagram for Amibios 686 ZL15 1317 Motherboard.
The manufacturer will have this information in PDF form most the time and keep this information for a number of years. Assuming you're looking for the pin outs for the motherboards power button, HDD light, and other indicator lights and functions. Also - If you look real close to the sides of the pins, you'll see indicators to show where everything goes. Hope this helps.
Nov 11, 2016 | Computers & Internet
Soyo Tech aid response 2A: "different BUSes" on 1999 AMI Bios on ECS P4800 Pro-M VI.0A pc motherboard.Won't boot but stops. How to fix?
Visit http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=574&LanID=9
and compare that is your BIOS updated ? If not, I suggest first update your BIOS to the latest version and see if error is removed ? Try Load Optimal Settings of BIOS. If fail, then try resetting the BIOS. If you have install anything new, try to boot by removing the new device. I suggest from the above URL, you can download the manual of the mother board. I hope trying these steps will remove your problem.
Feb 11, 2016 | Intel PENTIUM-4 FSB800 Mother Board with...
686 amibios 1999
You could add a new NIC to the computer which is cheaper ($10), as long as you have the ability to add. You could also get a USB ethernet adapter. Have you tried to update the drivers and firmware of the NIC?
Nov 26, 2013 | Dell Ethernet Card Network Adapter
Mobo 001d9298691c welke drivers
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Feb 22, 2013 | Packard Bell Computers & Internet
I need motherboard driver and setup spec for VER:5. The board does not boot to BIOS or provide video via AGP or PCI. BIOS chip label stamped BK40 3457 (686 AMIBIOS). I DO NOT KNOW HOW TO CONFIGURE THIS...
May 02, 2011 | Computers & Internet
Bios update
go online and type in
bois download drivers
enter
manifacture name bois model # [date if u have one] download drivers
rod
Dec 16, 2008 | ASUS P4S800-MX Motherboard
A driver that won't install
alberts18,
Here is the issue, ECS doesn't list a M925 solely board so please look at this link and verify what you have for me ..
Dec 11, 2008 | Computers & Internet
Computer will not boot
The code A6 indicates bad memory. If it is new take it back or replaced under warranty.Most memory manufacturers have a lifetime warranty.
If it came with the new computer, take the whole computer back and get it replaced under warranty.
Please let me know how you make out.
thanks
Jan 26, 2008 | Intel Motherboard
Motherboard manual ?
is jumpers on 1 and 2 good power test ram front conecter on pw
Jan 23, 2008 | Computers & Internet
P4mmv2 motherboard
If its a P4mmv2 motherboard with AMIBIOS 686 and a VIA VT8233 chipset then the jumper setting are printed on the motherboard, but they have labeled the power switch wrong, I believe th reset switch is the power switch. This is the type of mother board that I have and I have learned this from experience. Also I read in somewhere on the internet about the problems with these types of motherboards.
Jun 04, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
