Question about Doro PhoneEasy Cell Phones
Bought the doro 621and removed the battery cover to insert the SIM and battery but now I can't close the battery cover
Battery cover clicks into place on one side but not the other, how do I fix this?
  • 111 Answers
SOURCE: invalid battery, and unable to charge
i tried changing my battery and it worked..if not you can always have it reprogrammed
Posted on Jan 11, 2008
SOURCE: how to remove face plate
how to remove a contact person in "my fave". motorola zoom 4x
Posted on Aug 01, 2008
  • 75 Answers
SOURCE: cant open battery cover
Hello!
Very simple solution. All you have to do it flip it over to the back cover is facing you, there is either a tiny button to push and then you can release the cover. Or you need to press firmly against the back and front and push up/pull down until the cover slips off!
Please rate FixYa!
Posted on Jan 12, 2009
SOURCE: I can't remove battery cover of new samsung j700
Get some bluetack and place underneath the samsung logo on the battery cover and press down on it firmly to secure the bluetack, then to remove press down really firmly and slide in an upwards motion.
Posted on Feb 19, 2009
  • 17 Answers
SOURCE: HTC Desire HD battery cover difficult to remove
you may want to take it back to where you purchased it and let them know what you are experiencing maybe they can either repair it or replace it with another phone
Posted on Dec 08, 2010
Inserting sim card
There is often a tiny slot hidden behind the battery inside the phone. Try removing the battery cover and take the battery out, then you should find the sim card slot. It will be very small. Don't force it in- It should only fit one way, so if it resists, flip the card around and gently push it in until it clicks or stays in place. Insert your batter, replace the cover, and it should work.
Sep 07, 2016 | Cell Phones
How to remove sim card from nokia x3-02
1.Insert a SIM card. Make sure the contact area of the card is facing down
2.Press the release buttons, and remove the cover. If the battery is inserted, lift the battery out.
3.Line up the contacts of the battery and the battery compartment, and insert the battery. To replace the back cover, direct the top locking catches toward their slots, and press down until the cover locks into place.
Nov 29, 2012 | Cell Phones
Mobile phone will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 02, 2012 | Doro Phoneeasy 410Gsm Easy Gsm Sim Free...
Nokia c7 sim card removal i don't now how ??
Insert the SIM card and battery
Important: Do not use a micro-SIM or a micro-SIM with an adapter in this device. This device does not support use of micro-SIM cards, and use of incompatible SIM cards may damage the card or the device, and may corrupt data stored on the card.
Follow the instructions carefully, to avoid damaging the back cover.
Safe removal. Always switch the device off and disconnect the charger before removing the battery.
1 Unlock the back cover release latch, and lift the back cover
2 If the battery is inserted, lift the battery out.
3 Insert a SIM card. Use the diagram printed on the device to correctly align the card.
4 Line up the contacts of the battery and the battery compartment, and insert the battery.
5 To replace the back cover, direct the top locking catches toward their slots, and press down until the cover locks into place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Nokia C7 (8 GB) Smartphone
Where do i put the sim card
The majority of phones have the sim slot located under the battery.
1. Hold down the release button for the battery cover and lift off the battery cover. 2. Insert sim. 3. Insert the battery so that the metal contacts on the battery align with the metal contacts on your device. 4. Replace the battery cover back onto the device so that it clicks into place.
Apr 30, 2011 | RIM BlackBerry BlackPearl Flip 8230 Cell...
I bought my wife Conair massaging slippers model VSW32. There was no instruction manual. I need to how to install the batteries. Can you help
Underneath the pink inside sole is a box for the battery. Pop the plastic cover with a small screwdriver. Install 1 "AAA" battery in each slipper and replace plastic cover. The button to turn the massage off and on is on the side of each slipper on the outer sole.
Dec 25, 2010 | Clothing Accessories
Insert sim how can i do
The SIM card goes under the battery in the back of the phone. First you'll need to remove the battery cover, then remove the battery. Insert the SIM card with the gold contacts facing down and the notched corner toward the inside. Reinsert the battery and close the cover. I hope this helps. Good luck
Oct 17, 2009 | Sony Ericsson K850i Mobile Phone
How do I remove the battery and put the sim card in my new nokia 2760 cell phone
These are steps from the Nokia 2760 manual found at :
http://nds1.nokia.com/phones/files/guides/Nokia_2760_UG_en.pdf
(pages. 12-13)
1. Press and slide the back cover toward the top of the
phone to remove the cover .
2. To remove the battery, lift it as shown
3. Carefully lift the SIM card holder from the finger grip
of the phone, and open the flip cover
4. Insert the SIM card, so that the bevelled corner is on
the upper left side and the gold-colored contact area
facing downward.Close the SIM card holder, and
press it to lock it into place
5. Insert the battery into the battery slot
6. Align the back cover with the back of the phone. Slide
and push it toward the bottom of the phone to lock it
Apr 14, 2009 | Nokia 2760 Cellular Phone
Insert sim card
If you want to insert your sim card into your mobile, open the back cover, remover the battery and insert the sim into the slot provided. Put back the battery, close the back cover and then use the mobile.
Nov 01, 2008 | Nokia 6300 Cellular Phone
Sony ericsson t303, how do i open the back cover to put in my simcard?
To insert the simcard and battery:
1.Remove the battery cover by sliding it outward from your phone
Slide the SIM card into its holder with the contacts facing down.
2. Insert the battery with the label side up and the connectors facing each other. Then replace the battery cover by sliding it back, now inwards.
Note: Do not force the battery cover to its place. Slide the battery cover carefully onto the phone and close it.
For the online manual of your phone, check out the URL below:
http://www.sonyericsson.com/cws/download/1/497/033/1216462727/T303__UG_EN_1210_1909_1.pdf
Oct 14, 2008 | Sony Ericsson Cell Phones
Cell Phones Logo
11 people viewed this question
Top Doro Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
terry stevens
Are you a Doro Cell Phone Expert? Answer questions, earn points and help others
