Question about Dishwashers
Does the spray arms come off on a amana dishwasher?
SOURCE: dishwasher - no spray arm action
I also had this problem and it turned out to be a small piece of a drinking glass that had made it all the way to the chopper and wedged between the blade and the housing. I was able to do all of the work from inside the dishwasher without disconnecting anything.
Posted on Apr 16, 2008
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
SOURCE: Dishwasher upper arm does not spray
possible ball valve problem
Posted on Jan 03, 2009
SOURCE: frigidaire fdb949gf dishwasher won't spray water from arms
I found on my first dishwasher the arm holes were plugged. I had to clean out each and every hole with a small wire. They would not even turn until I cleaned them God luck.
Posted on Jan 31, 2009
  • 423 Answers
SOURCE: Frigidaire Dishwasher - Spray Arm Not Working
When a dishwasher has been checked for obstructions in the sump area and the spray arms can spin easily (by hand) plus the spray arm holes are not blocked, you end up with either a broken impeller or a failing wash pump motor.
If you would like more details of have more questions, please post comment back here, OK?
Good Luck!
Posted on Apr 26, 2009
Water not spraying out hard enough
Check water inlet valve (solenoid) for a clogged inlet screen and for proper operation (ensure full opening of the valve); check the main(undersink) water connection for an obstruction or partially closed valve, and check the lines/tubes throughout for obstructions - scale, collapsed line, etc.
Oct 04, 2012 | Amana ADB1600AWW Builtin Dishwasher
My Amana ADB1600AWB1 dishwasher is acting up. most of the top rack items, especially coffee mugs are not getting clean, most of them dont even look like they get wet. now tonight most of the bottom rack...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenanceDishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 04, 2011 | Dishwashers
My Amana Softsound 2 isn't getting dishes clean - the lower arm doesn't rotate. We cleaned around and under the arm as much as possible, got some gunk out from under, but still not rotating, so...
Check the nozzles of the arm themselves. if you found lots of gookl there maybe some inside the arms blocking the spray holes which cause it to spin
Jul 15, 2011 | Amana ADW862EA Built-in Dishwasher
Soap dispenser opens up but soap doesn' talways run out
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Jan 05, 2011 | Amana Dishwashers
Dishes are not cleaning properly in my Amana dishwasher. It has worked well previously.
Dishwasher
How to Buy
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Amana 24 in. ADB1500AWS Stainless Steel...
Dishwasher was not cleaning dishes bottom filling up with water but not spraying out the rotators
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Nov 06, 2010 | Amana 24 in. ADB1500AWS Stainless Steel...
Dishes in bottom rack are noy getting clean
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
heatman101 ..
Nov 04, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
Dishwasher is not spraying water
check that you aren't blocking the spray arms with items you have loaded into the dishwasher. Make sure that things such as pot handles or silverware is not obstructing the arms
Sep 16, 2010 | Amana 24 in. ADB2500AW Built-in Dishwasher
Lower arm does not spin, but water sprays from from the jets
Something is jamed around the pivot point of spray arm, force it just a tad, not to break anything more than what might be jamming it. You might have to take it apart to remove the cause.
Is there enough water pressure to spin the arm ?The arm should spin freely.
Oct 25, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Dishwashers Logo
18 people viewed this question
Top Dishwashers Experts
