Question about Whirlpool 3.2 cu. ft. Plus Washer
Belt replacement for LSR7233EQ0 - Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool Model# LSR7233EQ0
Check the level sensor and the drain pump for clogging, if this is clean then the control panel is a suspect as the processor does not advance in cycle
check for tips : washing machine tips .
Jul 03, 2012 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool LSR7233EQ0 Squeals
There are dogs in the agitator and they can vibrate and growl at times. An easy check for this is to turn the top of the agitator either way briskly and see if the dogs engage. If they do, just lube them sparingly with lithium spray lube, silicone spray or Vaseline. Also make sure while the agitator cap is off that the agitator bolt on top is sufficiently tight.
Your squealing sound is the result of a worn drum brake which affects both the spin and brake function of the inner tub. For my step by step detailing access to this part, take a look at my tip on disassembly here\/\/\/
http://www.fixya.com/support/r4355933-washing_machine_repair_direct_drive
Mar 24, 2010 | Washing Machines
Good afternoon - I have a Whirlpool model LSR7233EQ0 washer. The washer works fine in regards to draining, filling, lower agitator works...however, the top agitator does not engage and almost sounds like...
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. For the model number you have listed, the part number for the kit is 285811 and sells for about $11.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Dec 16, 2009 | Dishwashers
Whirlpool lsr7233eq0. The machine is level but
Grab back of washer on both sides and tip towards you and drop gently back. This will level the back legs which are self adjusting. Sometimes they stick You may have to pry with a screwdriver down towards floor to free them if this is the case.
Jul 07, 2009 | Whirlpool Washing Machines
obviously, the motor is not running at all and you are only getting your cloths wet. There are sequential event not taking place and sounds to me, too complex to resolve on your own (you need test meters and knowledge what to test) I suggest that you call for a service tech to check the washer
Jul 31, 2008 | Washing Machines
Whirlpool top loader washer LSR7233EQ0 drains, but does not spin. Best troubleshooting advice?
You probably broke the coupler between the motor and transmission. However If it agitates the coupler is not broke.
May 04, 2008 | Washing Machines
Does not spin
The close pin most likely broke the switch. Unplug the washer, remove the screws that hold the top and flip it back and remove the cabinet. with the cabinet off it is easy to replace the lid switch. Cost should be $20. to $30.
God Bless and Happy New Year.
Dec 31, 2007 | Whirlpool LSR6334LQ Top Load Washer
Whirlpool 3.2 cu. ft. Plus Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
